To those of you with slammed CRX's
Old Jan 25, 2005 | 06:48 PM
StupidSlowRSX's Avatar
Default To those of you with slammed CRX's
I have the neuspeed race springs 2.0" front/2.25" rear and of course now I have camber problems... I have the ingalls kit on the car but in order to fully adjust it I need to cut some of the subframe out. I have a heavy duty sawzall(solvesall)
My question, to those of you with slammed rex's
How did you go about doing this? Ive tried with a sawzall ones and everytime I hit the subframe the sawzall shot out of my hands. I've read that a torch is the best way to go.
Any opinions?
Old Jan 25, 2005 | 06:50 PM
HatchBox's Avatar
Skoobie no more...
Default Re: To those of you with slammed CRX's (StupidSlowCRX)
BFH?
Big ******* hammer.
Old Jan 25, 2005 | 06:55 PM
Default Re: To those of you with slammed CRX's (HatchBox)
a big chunk has to be cut out.. I dont think a hammer will do
Old Jan 25, 2005 | 07:08 PM
ecovillain's Avatar
hey not sure how to solve your problem but check this out: https://honda-tech.com/zerothread?id=1127451
Old Jan 26, 2005 | 02:56 AM
Default Re: To those of you with slammed CRX's (ecovillain)
Ya.. Thanks I already read that when I did a search
Old Jan 26, 2005 | 03:05 AM
HatchBox's Avatar
Skoobie no more...
What intagals kit do you have the 4 peice?
Maybe pictures would help
Old Jan 26, 2005 | 04:07 AM
shai x boi racer's Avatar
well I used a dremil and just cut through it... or you can use the oversized dremil ... i forgot what it was called but thats a bit harder considering the size...
I love the dremmil... quick fix in the tightest places... specially the pen tool... yea...
you might have to replace the cutter a couple times... but its the best way... just cut out about an inch and a half about ... 1/2 - 3/4 inch deep... thats a guesstimation but it should be right ... it just needs to clear that part and it will swing passed...
fair warning tho... i have my car slammed that low... (not by choice, spindle is stuck/ frozen/seized together and now my tranny was chipped and grinded down because of railroad tracks/ UNEVEN / REPAVING ROADS. and im leaking real bad because I can see the bolt that holds the gear casing to the bearing casing. slammed looks nice but can be too much hastle w/ cops and f'd up roads. oh and im on my third f'd up oil pan. which is very difficult to find.
Old Jan 26, 2005 | 06:23 AM
IO_303's Avatar
First make sure you have a metal cutting blade on the saw. Next get yourself a can of WD-40. What you do is spray the area your cutting with the WD, then begin cutting. Also keep spraying the area with the WD from time to time when you are cutting to keep the blade cool
Old Jan 26, 2005 | 08:33 AM
Mr_CRX's Avatar
I used a Makita grinder with a 4" metal cutting disc. I made about 5-6 vertical cuts and then used a hammer/pliers to bent the sections back and forth until they broke off.
Old Jan 26, 2005 | 09:04 AM
HatchBox's Avatar
Skoobie no more...
Default Re: To those of you with slammed CRX's (Mr_CRX)
i have the ingalls kit, and i dont know what you guys are cutting....
Old Jan 26, 2005 | 12:21 PM
Wes V's Avatar
Me and Mr_CRX think much the same way!
I use my Mikita with 4" cut-off wheel ALL the time. I have two of the Mikita's and a 5" Black&Decker.
Don't use a cutting torch! You will get too much distortion and that will lead to more working getting it correct.
Mr_CRX; send me a photo please! ( think you already have my e-mail address)
Wes
Old Jan 26, 2005 | 12:26 PM
RCautoworks's Avatar
Cutting disc on an angle grinder
Old Jan 26, 2005 | 12:47 PM
.Noah Fecks's Avatar
Default Re: To those of you with slammed CRX's (90blackcrx)
i installed an ingalls kit on my friends rex with nuespeed springs and konis. push the upper a arm asd far outward as possible, and tighten it down good. put everything back together... let the a arms do the work aka the bending of that lip under there.
Old Jan 26, 2005 | 02:53 PM
CrxEDguY's Avatar
Default Re: To those of you with slammed CRX's (Noah *****)
when i dropped my crx i also had camber problems but i went to a little hole in the wall place and they used a camber plate and bent the lower arm which solved that camber problem. no kits needed.
Old Jan 26, 2005 | 05:56 PM
Ls Crx's Avatar
the other guy that said bfh meant instead of cut it out pound it out of the way
Old Jan 26, 2005 | 05:57 PM
Default Re: To those of you with slammed CRX's (CrxEDguY)
Cool.. Im gonna try the WD-40 thing.. As it stands im riding on 195/60/15.. SOmetimes I have rubbing problems.. Sharp turns. Im switching to 195/50/15 Azenis when I get this stupid camber problem fixed.
riceburners1's Avatar
my car is maxed out on ground control coilovers....minimal camber issues....NO camber wear
kasperxtcy
Suspension & Brakes
Sep 28, 2007 11:57 AM
IntegraDriver
Suspension & Brakes
Feb 11, 2005 07:20 PM
Kaan
Apr 9, 2003 09:09 PM
b18c5go
Nov 23, 2002 11:55 AM
