d16y8 head swap for 90 si rex
Old Jan 25, 2005 | 04:40 PM
Rex Junkie's Avatar
Default d16y8 head swap for 90 si rex
I've read about it, is it possible? I need better flow, and VTEC
What other mods would i need to preform to make this work as far as wiring, ecu, and that jazz.
Your comment would be greatly appriciated
Old Jan 25, 2005 | 05:40 PM
CRX_Control's Avatar
Default Re: d16y8 head swap for 90 si rex (Rex Junkie)
https://honda-tech.com/zerothread?id=1127170 take that minus the mpfi wiring.you should search next time, there is tons of thrends about this kinda ****.
Old Jan 25, 2005 | 06:06 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rex Junkie &raquo;</TD></TR><TR><TD CLASS="quote">I need better flow, and VTEC
When you add a Y8 head to your A6 block, you get vtec. You do not, however get better flow. The A6 head flows better than a Y8 head.
Old Jan 26, 2005 | 05:54 AM
Rex Junkie's Avatar
Default Re: d16y8 head swap for 90 si rex (Mach69)
so what is actually better. "good" flow , or vtec? How can i get the best of both worlds?
Thanks
Old Jan 26, 2005 | 07:39 AM
CRXDrew's Avatar
vtec is nice but it really depends on your end goal.
I did a Z6 mini-me which was great fun N/A. But now that I'm turbo'd its a lil harder to tune.
Old Jan 26, 2005 | 07:50 AM
Rex Junkie's Avatar
Default Re: (CRXDrew)
Funny, my name is Drew. cool. well, good luck with your tuning.
I want a forcrd induction setup, and Vtec would would give me more fuel, right?
But so would an ecu and injectors, i'm an idiot
Old Jan 26, 2005 | 08:18 AM
turboLSef's Avatar
I heard the Z6 head flows pretty good for sohc head and it has vtec... I dont know how the flow compares to the A6 head.
Old Jan 26, 2005 | 08:49 AM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">
When you add a Y8 head to your A6 block, you get vtec. You do not, however get better flow. The A6 head flows better than a Y8 head. </TD></TR></TABLE>
Where is your data to back this up?
If you're going to do a head swap go with y8/z6.
Stock for stock a z6 head will flow better than a y8 head due to the y8's offset intake ports. The y8 has these to induce a swirl effect in the combustion chamber helping emissions and torque.
If you want to get creative i'd say get a y8 head and some dremel bits and clean that sucker up with a little homade porting. Y8 head will yeild higher compression as well as resist detonation due to it's quench areas in combustion chamber. My head was done by Joe Alaniz and would probably match a similarly ported Z6 head as the intake offset was made less dramatic but still effective.
I don't know what your budget/goals are but i speak from experience. I just tuned my y8 setup and made 143whp and 112wtq on pump gas on Jeff Evans Dynapack setup. This translates to ~160whp/125wtq on a dynojet going by the way Jeff Evan's dynapack reads in relation to other cars compared on both dyno's.
Note: dynapacks can read higher/lower than dynojets depending on how operator sets peramiters/sensors, however they are a superior tuning dyno producing very consistant numbers as opposed to dynojets.
Vince
Old Jan 26, 2005 | 10:56 AM
Default Re: d16y8 head swap for 90 si rex (AgentJam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">Where is your data to back this up?
Vince</TD></TR></TABLE> agentjam knows his stuff , i will one day have something close to his set-up with the sohc.
shawnperolis
17
Aug 30, 2013 11:19 AM
CR3X
Nov 27, 2007 08:37 PM
gmctruck1968
Aug 17, 2006 04:43 PM
SLOW93LX
Feb 7, 2006 11:26 AM
jlebeau
Dec 9, 2004 02:55 PM
