suspension help asap
Old Jan 25, 2005 | 04:22 PM
98-0688's Avatar
Default suspension help asap
how do you seperate the ball joint from the upper control arm on a 6th gen accord?
Old Jan 25, 2005 | 04:45 PM
98-0688's Avatar
Default Re: suspension help asap (98-0688)
anyone
Old Jan 25, 2005 | 04:54 PM
SuperSlow's Avatar
With a press. take it off and run down to the nearest shop... unless you got one of your own to use.
Old Jan 25, 2005 | 04:58 PM
98-0688's Avatar
Default Re: suspension help asap (SuperSlow)
alright thanks man
Old Jan 25, 2005 | 05:30 PM
syclone's Avatar
ball joint seperator.. you can rent one from autozone.. or you can use the fork style joint seperator if you don't plan on reusing the upper arm.
i didn't re-use mine, so i used the fork style one..
Old Jan 25, 2005 | 06:11 PM
k-mart's Avatar
Default Re: suspension help asap (syclone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syclone &raquo;</TD></TR><TR><TD CLASS="quote">ball joint seperator.. you can rent one from autozone.. or you can use the fork style joint seperator if you don't plan on reusing the upper arm.</TD></TR></TABLE>
yea, but he is asking how to separate the ball joint from the upper control arm once it is separated from the steering knuckle
and SuperSlow, how does a press work?
Old Jan 25, 2005 | 07:37 PM
iam7head's Avatar
Default Re: suspension help asap (k-mart)
a press is a press, it's a machine that press out/press in part(joints, rotor, seized part, suspenion bushing, etc.
honda only sells them on piece(with the uca), when my ball joint went bad, i had them replaced by the pair.
Old Jan 25, 2005 | 09:53 PM
syclone's Avatar
Default Re: suspension help asap (iam7head)
my bad.. yeah.. a press..
InTheZoneAC
Suspension & Brakes
19
Jan 22, 2014 05:21 AM
jwbnavy
12
Nov 28, 2007 06:36 AM
jojowasha
Jan 14, 2007 01:49 PM
DaChoZn1
Sep 18, 2005 03:34 PM
integra15
Nov 29, 2003 11:24 AM
