Spoon drain plugs ????
Old Jan 25, 2005 | 03:30 PM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
Default Spoon drain plugs ????
Why does my spoon oil drain bolt not screw all the way in? Use both washers right? and it still has threads showing?
Old Jan 25, 2005 | 03:32 PM
Nishant's Avatar
Default Re: Spoon drain plugs ???? (01ITR#173DC2ning)
both washers? only use one
Old Jan 25, 2005 | 03:33 PM
Default Re: Spoon drain plugs ???? (Nishant)
I was saying that even with both on, there is still threads showing.... Is that normal? also why are there 2 washers incld.
Old Jan 25, 2005 | 03:35 PM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01ITR#173DC2ning &raquo;</TD></TR><TR><TD CLASS="quote">also why are there 2 washers incld.</TD></TR></TABLE>
So that you have a new one come next oil change. They are crush-washers, only to be used once.
Old Jan 25, 2005 | 04:05 PM
KayOs's Avatar
It's always good to know what all the parts are for before installing. Good luck!
Old Jan 25, 2005 | 04:06 PM
Opie's Avatar
I never have any problems with my Sp00m plugs, are you threading it in right?
Old Jan 25, 2005 | 04:09 PM
B2FiNiTY's Avatar
Default Re: (opie)
Short is for tranny, long is for oil.
Two washers is because one each.
If you are having trouble threading it in, it is most likely the threads on your oil pan are damaged.
Old Jan 25, 2005 | 04:38 PM
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Short is for tranny, long is for oil.
If you are having trouble threading it in, it is most likely the threads on your oil pan are damaged. </TD></TR></TABLE>
i have total of 4 washers.... 2 per plug..... and yeah there threading correctly
B2FiNiTY's Avatar
Default Re: (01ITR#173DC2ning)
If it threads in fine, then what is the problem?
Old Jan 25, 2005 | 04:40 PM
As posted from the start, It still shows threads. In other words its not fully screwing in. I even put both washers on just for curiosity and there was still threads....
Nishant's Avatar
only supposed to have one washer per plug, where'd you get the extra 2?
Old Jan 25, 2005 | 04:57 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: (Nishant)
make sure you got a 100 guns a 100 clips first , then make sure you have transmission and engine plugs mixed up
Old Jan 25, 2005 | 06:09 PM
B2FiNiTY's Avatar
As a test, try your stock drain plug and see if it goes in without a hitch, if so, then the threads on the spoon drain plug are damaged. If the stock drain plug also has trouble threading in all the way then you have a problem with the threads in your oil pan.
Old Jan 25, 2005 | 06:22 PM
Stolen R's Avatar
When i first got my Spoon drain plugs, they were installed by the Acura mechanic during and oil change. She put the oil plug in and asked me if i'm sure it was the right part. For some reason it wasn't in all the way and like the poster stated, there were still a few threads exposed. You just have to lay into it a little and it will thread all the way. The Spoon plugs must have more thread going into the pan or something like that.
Old Jan 25, 2005 | 06:38 PM
Chris F's Avatar
Default Re: (Leo S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo S &raquo;</TD></TR><TR><TD CLASS="quote">When i first got my Spoon drain plugs, they were installed by the Acura mechanic during and oil change. She put the oil plug in and asked me if i'm sure it was the right part. For some reason it wasn't in all the way and like the poster stated, there were still a few threads exposed. You just have to lay into it a little and it will thread all the way. The Spoon plugs must have more thread going into the pan or something like that. </TD></TR></TABLE>
Sounds reasonable, unless you're hitting the oil pickup or something... Can you peek in there to see if there's something in the way? It doesn't seem like there should be.
Hey, how come Leo S gets a title, and us suckers don't?
-Chris
Old Jan 25, 2005 | 07:51 PM
Default Re: (Chris F)
Cause he/she shelled out for an iServe account...and thus he/she is better than us.
Old Jan 25, 2005 | 07:58 PM
The Kernel's Avatar
Default Re: (Leo S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo S &raquo;</TD></TR><TR><TD CLASS="quote">You just have to lay into it a little and it will thread all the way. The Spoon plugs must have more thread going into the pan or something like that. </TD></TR></TABLE>
Old Jan 25, 2005 | 08:13 PM
Pondus's Avatar
Default Re: (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">Cause he/she shelled out for an iServe account...and thus he/she is better than us.</TD></TR></TABLE>
Old Feb 1, 2005 | 09:46 PM
Default Re: (Leo S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo S &raquo;</TD></TR><TR><TD CLASS="quote">When i first got my Spoon drain plugs, For some reason it wasn't in all the way and like the poster stated, there were still a few threads exposed. You just have to lay into it a little and it will thread all the way. The Spoon plugs must have more thread going into the pan or something like that. </TD></TR></TABLE>
Very true. that was the problem. They were just really tight and I was only trying to NOT strip any threads.....
Old Feb 1, 2005 | 09:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">only supposed to have one washer per plug, where'd you get the extra 2?</TD></TR></TABLE>
Mine came to me with 2 washers per plug, I bought the set.... I got the spoon box with it....
Can someone post a pic of the plugs in there plastic packaging please? I cannot seem to find a pic........ t i a
Old Feb 1, 2005 | 10:05 PM
cxSHOE's Avatar
Can someone post a pic of the plugs in there plastic packaging please? I cannot seem to find a pic........ t i a</TD></TR></TABLE>
you get a total of 4 washers. and you use one washer per plug when you doing your oil changes ....(you have 2 extra washers for the next time)
Old Feb 1, 2005 | 10:12 PM
ok ok.... good deal..
Old Feb 2, 2005 | 03:44 AM
furious94ls's Avatar
Default Re: (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly. For the record I have these plugs as well. No problem with them screwing in all the way.
Old Feb 2, 2005 | 03:53 AM
Jon D's Avatar
HOw many whp is that plug putting down
Old Feb 2, 2005 | 04:49 AM
Default Re: Spoon drain plugs ???? (Jon D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D &raquo;</TD></TR><TR><TD CLASS="quote">HOw many whp is that plug putting down </TD></TR></TABLE> Adds exactly 13 hp to the wheels.... Vrooooooooom!
Here's the story, I wouldn't have payed the price these things cost but I was searching eBay for magnetic drain plugs and ran accross these plugs claiming they were Spoon. Here it is..... Buy It Now $.99... I knew it was a typo and should have been maybe 19.99 but I hurried and clicked buy it now and payed imediately. Anyway he emailed me and said he made a mistake but would send it to me anyway since it was a fault on his behalf.... I never thought it would come but not only did it show up in 6 days, But it was a pair..... hahahahaha
