Weighed my EG today
Old Jan 25, 2005 | 03:27 PM
revolt_allmotor's Avatar
Default Weighed my EG today
Put it on the scale at a local metals place. It's a giant scale that you can drive semis on to. Car weighed 2000lbs with 1/4 tank of gas.
Car info:
94 Civic DX hatchback
LS/VTEC (b18a block/b16 head)
No AC or heater (all under-dash components removed as well)
No P/S
gutted dash ( https://honda-tech.com/zerothread?id=892008 )
all carpet and sound deadening removed
all interior trim except door panels and headliner removed
front and rear bumper support bars removed
driver's seat replaced with Recaro Profi SPG
stock steering wheel/airbag replaced with Omnipower quick release/Esper wheel
wheels 15x6.5 Rota Battle w/205/50/15 Falken Azenis
edit: forgot to mention ViS carbon hood and lightweight 11lb battery...
Modified by 909edge at 11:29 PM 1/26/2005
Old Jan 25, 2005 | 03:38 PM
BDogggUT34's Avatar
Default Re: Weighed my EG today (909edge)
Nice!! How much is the LS/vtec setup puttin out?
Old Jan 25, 2005 | 03:43 PM
lohatch's Avatar
not bad at all. my 92 hatch weighed in at 2220lbs with me in it. full interior. no AC or front bumper support. sohc with a turbo kit in the engine bay. that was a year ago though. might be a little lighter now.
Old Jan 25, 2005 | 03:48 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Weighed my EG today (lohatch)
I dont get it. You lost an entire 200 lbs off the car and its basically a stripped car now and goes what? .2 seconds faster? I dont know what you gain ET wise, if there is a weight loss/faster ET ratio, but cool for you I guess?
Cut the roof of the car off, theres probably a few hundred pounds to be lost there.
TedwardRoberts's Avatar
does that include you?
Old Jan 25, 2005 | 03:53 PM
dso's Avatar
dso
Default Re: Weighed my EG today (jlacoy82)
for every 500lbs you take off your car you lose a second off your 1/4 mile time and vice versa.
Old Jan 25, 2005 | 04:10 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Weighed my EG today (EG6_tuner)
Ok, .5 seconds shaved off.
Old Jan 25, 2005 | 04:13 PM
PRcivicHB's Avatar
a before and after of the weight would have been cool... 2000lbs seems like alot considering everything u took out. Mine must weigh damn near 3000lbs then... I have the same car by the way.... edit: but i have a single cam 75lbs less
Old Jan 25, 2005 | 04:31 PM
743power's Avatar
Default Re: Weighed my EG today (PRcivicHB)
mine weighed 2040, and all I took out was the passenger seat, carpet and rear seats, with a full tank.
That is a 94 cx with b series, full gsr brakes, heavy 14" wheels and tires, full exhaust, etc.
Old Jan 25, 2005 | 11:40 PM
Default Re: Weighed my EG today (743power)
yeah it seemed kinda high, I was expecting/hoping for closer to 1900. like I said this was a giant drive-on scale designed for semi-trucks, it was about 40-50 feet long. I don't know how accurate it is with so little weight. might try to weigh the car again on a better scale. I need to buy a set of cornerweight scales...
Old Jan 26, 2005 | 03:31 PM
bump - does anyone think that 2000 is kinda high considering all the weight reduction I have done?
Old Jan 26, 2005 | 03:35 PM
cnyej1's Avatar
Dont you think its a little weird seeing that your car came out to 2000lbs exactly? Usually those truck scales are within 50lbs like they weigh in 50lb increments.
Old Jan 26, 2005 | 03:42 PM
tealbubble's Avatar
Default Re: Weighed my EG today (cnyej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRcivicHB &raquo;</TD></TR><TR><TD CLASS="quote">a before and after of the weight would have been cool... 2000lbs seems like alot considering everything u took out. Mine must weigh damn near 3000lbs then... I have the same car by the way.... edit: but i have a single cam 75lbs less </TD></TR></TABLE>
.... no way and eg weighs 3 grand unless your weigh 600-800lbs or you carry a lot of **** in it i hope you were being sarcastic... if you have the dx with no p/s or moonroof your car weighs about 2200 stock... with no gas in it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6_tuner &raquo;</TD></TR><TR><TD CLASS="quote">for every 500lbs you take off your car you lose a second off your 1/4 mile time and vice versa.</TD></TR></TABLE>
and its every 100lbs is a tenth of a second off your 1/4mile time.. close but your doubling it...and getting peoples hopes up
corrected a lil if you got the wrong idea....
and also for the haters...sometimes its not the amount of weight its the center of gravity... less weight in the back more traction to the front end... 2000lbs isnt bad
Modified by fallenasleepek at 1:49 AM 1/27/2005
Old Jan 26, 2005 | 03:55 PM
Default Re: Weighed my EG today (fallenasleepek)
how much heavier is my LS/VTEC than a D series? about 70 pounds right?
Old Jan 26, 2005 | 04:37 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fallenasleepek &raquo;</TD></TR><TR><TD CLASS="quote">and also for the haters...sometimes its not the weight its the center of gravity... less weight in the back more traction to the front end</TD></TR></TABLE>
...are you serious? Just make a post saying "Yes, I'm serious," and I'll get right to work making you look like the biggest clown this side of physics.
Old Jan 26, 2005 | 04:42 PM
tealbubble's Avatar
Default Re: Weighed my EG today (Archidictus)
search bizi's car why do you think there are drag slicks in the front and bike tires on the back for nice looks???? you must be stupid more traction to the front means quicker hook up = better times.. get a life
hows the racing scene out there in ohio..?
Modified by fallenasleepek at 1:54 AM 1/27/2005
Old Jan 26, 2005 | 04:49 PM
chad's Avatar
Moderator
1940 with roll cage....full glass.....b20vtec kazz lsd....
Default Re: Weighed my EG today (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">1940 with roll cage....full glass.....b20vtec kazz lsd....</TD></TR></TABLE>
see that's were I was thinking I'd be... closer to 1900...
Old Jan 26, 2005 | 04:53 PM
FERIOkid's Avatar
^^^ not a man to be fucked with.....I'M SERIOUS
for smart people
Old Jan 26, 2005 | 05:03 PM
PRcivicHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fallenasleepek &raquo;</TD></TR><TR><TD CLASS="quote">.... no way and eg weighs 3 grand unless your weigh 600-800lbs or you carry a lot of **** in it i hope you were being sarcastic... if you have the dx with no p/s or moonroof your car weighs about 2200 stock... with no gas in it</TD></TR></TABLE>
I said if his weighs 2000lbs after all that weight reduction, mine should weigh 3000lbs... Like an Analogy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fallenasleepek &raquo;</TD></TR><TR><TD CLASS="quote">and its every 100lbs is a tenth of a second off your 1/4mile time.. close but your doubling it...and getting peoples hopes up</TD></TR></TABLE> Least u got that right...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fallenasleepek &raquo;</TD></TR><TR><TD CLASS="quote">corrected a lil if you got the wrong idea....
and also for the haters...sometimes its not the amount of weight its the center of gravity... less weight in the back more traction to the front end... 2000lbs isnt bad </TD></TR></TABLE>
Civics are notorious for too much weight up FRONT!!! You want to take as much weight out of the front, not the back.... Thats not the way to deal with bad traction...
Old Jan 26, 2005 | 05:05 PM
PRcivicHB's Avatar
Might wanna try and get it weighed at the local track?
tealbubble's Avatar
ya need a better analogy.. or at least say my car is to heavy as his car is to light now thats an analogy....:good sport:
Old Jan 26, 2005 | 05:09 PM
tealbubble's Avatar
Civics are notorious for too much weight up FRONT!!! You want to take as much weight out of the front, not the back.... Thats not the way to deal with bad traction...</TD></TR></TABLE>
damn guys he said it..once you get out your a/c, p/s and all the other useless b/s like cruise control.your kinda **** outta luck..unless you get a carbon fiber front..and start getting titanium engines... would be nice actually
i wonder why people gut their interiors??? hmmm : Ponders :
just leave em in if it doesnt do anything...
Old Jan 26, 2005 | 05:17 PM
PRcivicHB's Avatar
Im not going to argue with you.. Im not saying dont gut your car but you want to take more out the front because its already over weighing the back....
And why do u think alot of sports cars are designed with 50/50 weight distribution wise asz...
Old Jan 26, 2005 | 05:26 PM
tealbubble's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRcivicHB &raquo;</TD></TR><TR><TD CLASS="quote">Im not going to argue with you.. Im not saying dont gut your car but you want to take more out the front because its already over weighing the back....
And why do u think alot of sports cars are designed with 50/50 weight distribution wise asz... </TD></TR></TABLE>
maybe cuz they're not designed to go really fast in a straight line and they are made for overall performance... just a thought... but your right and im right... good...
