dpfi to mpfi question
Old Jan 25, 2005 | 03:20 PM
TEAM HATCH-N-IT 90's Avatar
Default dpfi to mpfi question
I have a 90 hatch dx. I have already changed the wireing and the ecu (pm6) and now i need to get the si distribitor but i was wondering if i could possible use the stock distribitor? It runs but it is flashing code 8. It is top dead center (tdc) and it is only reving to 3000rpms???????? any info would be great.
Kyle
Old Jan 25, 2005 | 03:22 PM
4drEF's Avatar
Keyboard Humorist
Default Re: dpfi to mpfi question (CIVICking90)
NO - you can't use that distributor.
It's got the wrong sensors in it so it can only run DPFI (2 injectors) rather than MPFI (4 injectors).
Old Jan 25, 2005 | 03:36 PM
Default Re: dpfi to mpfi question (4drEF)
ok thanks i wanted to Know before i bought the si dizzy.
Kyle
Old Jan 25, 2005 | 03:40 PM
4drEF's Avatar
Keyboard Humorist
Yeah - follow the DX to MPFI directions and you notice that you will be adding 2 wires to the distributor.
To make it all look good, not only find the distributor, but also make sure you have the engine harness plugs for it (they will have 2 more wire locations).
Old Jan 27, 2005 | 06:07 PM
zccr-xsi's Avatar
u need the si manifold si ecu si dizzy, the u need to wire in the two other injectors,
oh yea dont forget to get the si resistor box for the injectors.if u dont want to wire it i think u can replce the dx harness with si wiring harness that way all the injectors wires will be there already. other then that your set
EFinSi
Aug 10, 2007 04:22 AM
littlejackass
Mar 13, 2004 02:40 PM
Big Bang
14
Aug 22, 2003 06:18 AM
Elmdale
Sep 14, 2002 07:01 AM
Blaze45
Jul 17, 2002 06:09 PM
