Converted from Obd0 TO Obd1 problems !
Old Jan 25, 2005 | 01:09 PM
Euro98ITR's Avatar
Default Converted from Obd0 TO Obd1 problems !
A friend of mine just converted his B16a Obd0 to Obd1. A b16a Obd1 distributor was installed followed with a 4 wire 02 sensor by a qualified mechanic. Everything was wired correctly. The engine started but the CEL came on!
It gave these all these codes : 4, 9, 20, 21, 22, 41 .
Any suggestions ?
Old Jan 25, 2005 | 01:13 PM
CRX_Control's Avatar
Default Re: Converted from Obd0 TO Obd1 problems ! (Euro98ITR)
4 is ckp 9 is cyp , 21 is vtec , 41 is oxygen sensor.20 is electrical load detector.(he definatly didnt wire correctly)
Old Jan 25, 2005 | 03:24 PM
CrazyKoreanCrx's Avatar
Default Re: Converted from Obd0 TO Obd1 problems ! (CRX_Control)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote"> 4 is ckp 9 is cyp , 21 is vtec , 41 is oxygen sensor.20 is electrical load detector.(he definatly didnt wire correctly)</TD></TR></TABLE>
Totally agree with Control with the wiring part. How did the mechanic wired it up and is your friend using a jumper for the ecu? Like what was done.
Old Jan 25, 2005 | 03:31 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Euro98ITR &raquo;</TD></TR><TR><TD CLASS="quote">Everything was wired correctly.</TD></TR></TABLE>
No it wasn't or you wouldn't be getting codes like that.
Any suggestions ?
Find somebody that can wire it correctly.
Old Jan 25, 2005 | 03:36 PM
Default Re: Converted from Obd0 TO Obd1 problems ! (4drEF)
well anyways, how did you convert it? using a conversion harness?what brand?(pmed crazykoreancrx back)
Old Jan 26, 2005 | 01:18 AM
Euro98ITR's Avatar
The conversion was done by an Obd0 to Obd1 conversion Jkobdconversionharness.com
We will double check the wiring.
Old Jan 26, 2005 | 01:22 AM
Euro98ITR's Avatar
Anyone can supply a chart or some type of information about the wiring ?
Old Jan 26, 2005 | 04:23 AM
blo2k1's Avatar
Obd0 to Obd1 wiring harness.
53 to 45 pins. + 4
A - 18
B - 11
| pin_id | wire_color | pin_function | pin_name | 4G (pr3 pin)
| A1 | BRN | INJ1 | INJ1 | -&gt; A1
| A2 | YEL | INJ4 | INJ4 | -&gt; A7
| A3 | RED | INJ2 | INJ2 | -&gt; A3
| A4 | GRN/YEL | VTS | VTEC solenoid | -&gt; ADD -&gt; vtec selenoid
| A5 | BLU | INJ3 | INJ3 | -&gt; A5
| A6 | ORN/BLK | PO2SHTC | O2 sensor (heating element) | -&gt; ADD [o2 heater control -&gt;blk (under wht wire)]
| A7 | GRN/BLU | FLR1 | fuel pump (main relay) | -&gt; A12
| A9 | BLK/BLU | IACV | IAC valve | -&gt; A11
| A12 | GRN | FANC | engine coolant temp switch | -&gt; B4
| A13 | GRN/ORN | MIL | MIL (check engine light) | -&gt; B6
| A15 | BLK/RED | ACC | (a/c compressor clutch) | -&gt; B3
| A16 | WHT/GRN | ALT C | alternator | -&gt; B5
| A20 | RED | PCS | EVAP purge control solenoid | -&gt; A6
| A21 | YEL/GRN | ICM | ICM | -&gt; B15
| A23 | BLK | PG1 | ground *(main relay ground) | -&gt; A2
| A24 | BLK | PG2 | ground *(main relay ground) | -&gt; A4
| A25 | YEL/BLK | IGP2 | to main relay and to gound for o | -&gt; A13 [splice for o2 -&gt; blk (under grn)]
| A26 | BRN/BLK | LG1 | gound | -&gt; A18
| B1 | YEL/BLK | IGP2 | to pin A25 | -&gt; A15
| B2 | BRN/BLK | LG2 | ground to shields for CYP & TDC | -&gt; A16
| B5 | BLU/RED | ACS | a/c switch | -&gt; B8
| B9 | BLU/WHT | | starter signal | -&gt; B13
| B10 | ORN | VSS | vehicle speed sensor | -&gt; B16
| B11 | ORN | CYP P | CYP -P | -&gt; B10
| B12 | WHT | CYP M | CYP -M | -&gt; B12
| B13 | ORN/BLU | TDC P | TDC -P | -&gt; C3
| B14 | WHT/BLU | TDC M | TDC -M | -&gt; C4
| B15 | BLU/GRN | CKP P | CKP -P | -&gt; C1
| B16 | BLU/YEL | CKP M | CKP -M | -&gt; C2
| D1 | WHT/BLU | VBU | Back Up Power | -&gt; B1
| D2 | GRN/WHT | BKSW | brake switch | -&gt; C10
| D3 | | KS | Knock Sensor | -&gt; ADD -&gt; Knock sensor
| D4 | BRN/WHT | SCS | service check connector | -&gt; mil [toggle switch with ground]
| D6 | BLU/BLK | VTM | VTEC pressure switch | -&gt; ADD -&gt; vtec pressure switch
| D9 | WHT/RED | ALT F | alternator | -&gt; B14
| D10 | GRN/RED | ELD | electric load detector | -&gt; B19
| D11 | RED/BLK | TPS | TPS Signal | -&gt; C7
| D13 | RED/WHT | ECT | ECT sensor | -&gt; C6
| D14 | WHT/RED | PHO2S | O2 sensor | -&gt; C16 [splice for o2 -&gt; wht]
| D15 | RED/YEL | IAT | IAT sensor | -&gt; C5
| D17 | WHT/YEL | MAP | Map Signal | -&gt; C11
| D19 | YEL/WHT | VCC1 | MAP 5V | -&gt; C15
| D20 | YEL/BLU | VCC2 | TPS 5V | -&gt; C13
| D21 | GRN/WHT | SG1 | MAP GND | -&gt; C14
| D22 | GRN/BLU | SG2 | TPS GND | -&gt; C12 [splice for o2 -&gt; grn]
or do this
Simple Obd0 to Obd1 wiring harness.
A1 -&gt; A1
A2 -&gt; A7
A3 -&gt; A3
A4 -&gt; ADD
A5 -&gt; A5
A6 -&gt; ADD
A7 -&gt; A12/A14
A9 -&gt; A11
A12 -&gt; B4
A13 -&gt; B6
A15 -&gt; B3
A16 -&gt; B5
A21 -&gt; B15
A23 -&gt; A2
A24 -&gt; A4
A25 -&gt; A13
A26 -&gt; A18/A16
B1 -&gt; A15
B2 -&gt; A16/A18
B5 -&gt; B8
B9 -&gt; B13
B10 -&gt; B16
B11 -&gt; B10
B12 -&gt; B12
B13 -&gt; C3
B14 -&gt; C4
B15 -&gt; C1
B16 -&gt; C2
D1 -&gt; B1
D2 -&gt; C10
D3 -&gt; ADD
D4 -&gt; mil
D6 -&gt; ADD
D9 -&gt; B14
D10 -&gt; B19
D11 -&gt; C7
D13 -&gt; C6
D14 -&gt; C16
D15 -&gt; C5
D17 -&gt; C11
D19 -&gt; C15
D20 -&gt; C13
D21 -&gt; C14
D22 -&gt; C12
Old Jan 26, 2005 | 05:42 AM
Euro98ITR's Avatar
Default Re: Converted from Obd0 TO Obd1 problems ! (blo2k1)
We are still using Obd0 injectors. They are supposed to work ok with the OBD1 ecu.
Old Jan 26, 2005 | 06:17 AM
88civichbz6's Avatar
yes the injectors will work with the resistor box.
double check all of the wiring and did you cut and resoider the wires or make converson plugs
Old Jan 26, 2005 | 11:23 AM
Euro98ITR's Avatar
Default Re: (88civichbz6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88civichbz6 &raquo;</TD></TR><TR><TD CLASS="quote">did you cut and resoider the wires or make converson plugs</TD></TR></TABLE>
We are using a harness from blown90hatch .
Old Jan 27, 2005 | 04:20 AM
Euro98ITR's Avatar
Default Re: (Euro98ITR)
Anyone else can confirm that we dont need OBD1 injectors?
Old Jan 27, 2005 | 09:27 AM
if you wired up the injector resitor box then you use obd0 injectors bipass the box and you use obd1 injectors.
this is only true for obd-1 ecus
Old Jan 27, 2005 | 10:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88civichbz6 &raquo;</TD></TR><TR><TD CLASS="quote">if you wired up the injector resitor box then you use obd0 injectors bipass the box and you use obd1 injectors.
this is only true for obd-1 ecus</TD></TR></TABLE> yup. shouldnt throw the codes that your throwing anyhoot. jkconversion harnesses are good , so its just probably your wiring.
dayton_crx
Jan 30, 2007 01:58 PM
dkrex001
Oct 27, 2006 07:38 AM
BMWCReXXX89
Sep 20, 2006 07:28 PM
4ghatch
Nov 24, 2004 08:00 AM
alexsracing
Nov 14, 2004 01:37 PM
