Hooking up Autometer gauges using Greddy sensor
Old Jan 25, 2005 | 12:41 PM
KetteringITR's Avatar
Default Hooking up Autometer gauges using Greddy sensor
When i bought my ITR, the guy before me had put Autometer carbon series Oil Pressure and Voltage gauges in but never hooked them up. Now i dont know if when he bought the gauges whether or not it came with what was needed, but anyways i didnt have that stuff. Voltage shouldnt be a problem and for oil pressure, i bought a Greddy sensor that hooks in where the oil filter screws in. Since the directions are in japanese, im not sure if i need some hoses or something to plug into this sensor. Does anyone know what i need extra or how to hook this thing up? Thanks.
Old Jan 25, 2005 | 01:04 PM
Philly_NBP_R's Avatar
Default Re: Hooking up Autometer gauges using Greddy sensor (KetteringITR)
um, this probably won't work. I'm pretty sure you need to use the sensor that goes with the gauge (ie Greddy sensor with a Greddy gauge). Autometer and Greddy gauges are totally different...
but anyway, one of the wires from the greddy sending unit is the pressure signal, and the others are power and ground. Greddy guages also need swithched and unswitched power, not sure if this matters, but it might explain what all the wires are for coming out of the sending unit.
Old Jan 25, 2005 | 01:05 PM
Ausmith's Avatar
The calibration between the Greddy sender and the Autometer gauge will not match.
Old Jan 25, 2005 | 01:07 PM
Default Re: Hooking up Autometer gauges using Greddy sensor (Ausmith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith &raquo;</TD></TR><TR><TD CLASS="quote">The calibration between the Greddy sender and the Autometer gauge will not match.</TD></TR></TABLE>
bingo
what you should have done is bought the autometer sending units that go with your gauges.
b20forlife
Dec 30, 2009 03:18 PM
95accordh22a
May 20, 2005 08:24 AM
slowpokesi
Jun 25, 2004 05:29 AM
milf H U N T E R
May 31, 2003 09:45 AM
