Rota don't fit on RSX Bolt Pattern?!?!
Old Jan 25, 2005 | 11:15 AM
Teh_Oven's Avatar
Default Rota don't fit on RSX Bolt Pattern?!?!
Does anyone know why the store i just called told me that Rota Torques won't fit on an RSX because of the bolt pattern? they come in 5x114.3+35mm/47mm/48mm. What would be the proper size offset for rsx's at 17" or 18" then??
Old Jan 25, 2005 | 12:09 PM
Teh_Oven's Avatar
Default Re: Rota don't fit on RSX Bolt Pattern?!?! (Teh_Oven)
anybody?
Old Jan 25, 2005 | 12:41 PM
k20whitevic's Avatar
Try calling modacar.
http://www.modacar.com/Merchan...=ROTA
Old Jan 25, 2005 | 09:45 PM
MrBurner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teh_Oven &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know why the store i just called told me that Rota Torques won't fit on an RSX because of the bolt pattern? they come in 5x114.3+35mm/47mm/48mm. What would be the proper size offset for rsx's at 17" or 18" then??</TD></TR></TABLE>
the bolt pattern is 5x114.3 so i don't see why they are saying that the bolt pattern is off...i don't remember exactly what the offset on my wheels were since i got them so long ago, but i believe it was 42...but the ones you are talking about should still fit
Old Jan 26, 2005 | 01:10 PM
Halo's Avatar
Default Re: Rota don't fit on RSX Bolt Pattern?!?! (MrBurner)
also you have to make sure the center bore is correct our cars have a 64.0 bore size
Old Jan 26, 2005 | 06:15 PM
krystar's Avatar
acceptable offset range is like +38 to +48 or so. stock is 42mm IIRC
Old Jan 27, 2005 | 07:08 AM
Halo's Avatar
Default Re: (krystar)
sorry but 48 is not an acceptable offset,...........45 is the max any higher you will rub on the inside
EFstyle
13
Mar 5, 2008 10:35 AM
dc5Aspec'd
12
Oct 17, 2006 10:59 AM
Wattup Though 00
May 28, 2004 05:37 AM
DsITR
Jan 22, 2003 11:28 PM
Lo-Buck EF
Feb 3, 2002 02:54 AM
