valve lash specs for skunk2 stage 2 cams
What is the recommended valve lash setting for skunk2 stage 2 cams in b18c5 (stock head) ? I have heard that it should be bigger than stock ? I do not have skunk2 specs. Thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krystianitr »</TD></TR><TR><TD CLASS="quote">But If there is CR 12.5 ???Is there any relation?</TD></TR></TABLE>
No.
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krystianitr »</TD></TR><TR><TD CLASS="quote">Is there any special way to install skunk2 stage2 cams or do you drop them just like the stock ones ? </TD></TR></TABLE>
Just like stock unless you've got a lot of material off of the cylinder head or you are running big dome pistons. If that is the case you should check and double check clearances.
PYITR821
Mar 1, 2004 10:18 PM
sleepycivix
Nov 15, 2002 08:01 PM
sleepycivix
Nov 15, 2002 07:01 PM
Drinker
