Boosting my 404's.. Tuning options.
Old Jan 24, 2005 | 11:24 PM
no2unenolife's Avatar
Default Boosting my 404's.. Tuning options.
I'm kinda clueless on what to do so bare with me.
I have a 1997 LS motor with
404 Crower cams. with the crower valve spring and retainer kit.
It is currently tuned with an SAFC, great idle, running well.
I was planning to run boost with this setup.
The problem I think I have is how I should tune my fuel management.
I'm going to be running 450 cc injectors. I have the obd 1 conversion harness with an ecu, I was planning to run with Uberdata.
Should I run Uberdata with a Standard 450cc basemap for the moment? Would it be fine to run that along with my SAFC so my cams will still be tuned correctly?
Or should I run the SAFC hack?... the thing I'm afraid of doing that because I don't want to ruin my settings for the cams. Or is it more simple than I'm thinking.
Also I won't be able to get on a dyno for about a month or so.
Any advice would be greatly appreciated. Thanks
Old Jan 24, 2005 | 11:28 PM
mmuller's Avatar
Mad Scientist
Default Re: Boosting my 404's.. Tuning options. (climaxpinoy)
dont those have lots of overlap?
Old Jan 24, 2005 | 11:29 PM
notstock93's Avatar
Default Re: Boosting my 404's.. Tuning options. (mmuller)
Lots. You could widen the LSA with some cam gears, but you could just as easily sell them and run the stock cams for boost.
boosting on huge cams isn't the best idea, but it can work.
Old Jan 25, 2005 | 06:20 AM
IN VTEC's Avatar
Uberdata start up maps are notorious for still being way too rich, and using cams that could potentially pull less vacuum at idle would only exacerbate the problem.
If you're going to use Uberdata do it correctly from the start. Use a wideband and vacuum gauge (or datalogging) to calibrate the fuel delivery in the idle cells and street tune. Forego using the SAFC.
mynameizstitch
Jul 6, 2009 07:49 PM
JFG Kevin
Sep 23, 2004 09:09 AM
Quick Silver
Apr 22, 2003 02:55 AM
B2FiNiTY
Jun 4, 2002 06:51 AM
primoEF
Jan 15, 2002 02:21 PM
