rear disc conversion?
get everything off of the rear of the car. the knees, the spindles the rotors, any salvage yard should know what you will need for the conversion. you will need the cables out of the donor car if you want the e brake to work as well.
Here is a how too (check link below). You will need to grab the whole rear suspension & brake lines. On your civic you MUST retain your stock LCAs because the Integra ones are a different length. You will also need a proportioning valve from a 96-00 civic hatchback, or 99+ Si because the integra/civic/del sol ones are NOT compatable (ImportAutoSalvage.com can take care of that too). I don't know which E-brake cables you will need, so look that one up...
https://honda-tech.com/zerothread?id=1036267
optoomistic
Mar 22, 2005 11:43 AM
