Type R Momo Wheels with SRS
Does anyone know if the Momo wheel's off the ITR or CTRs with SRS Airbag... work on a EG while retaining the airbag?
93 Honda Civic Coupe
THanks
~Vince
THanks
~Vince
i doubt it, unless the srs system is the same. they use their own little computers, just like your ecu. the ecu in a civic, wont work on an integra engine. probably same thing for SRS. you will most likely have to get the srs computer from that same car, i don't know if the plugs are the same. They should be. then that should do it for you, unless it doesn't bolt up right. But i don't see that as being a problem.
perseverance
Jul 25, 2007 09:48 AM
zerogravitycrx
Sep 26, 2005 02:06 PM
MADEinJAPAN
Jun 17, 2003 05:54 PM
