Drove around all day perfectly fine. Now it won't start...HELP!
Old Jan 24, 2005 | 08:28 PM
*Boostwerks*'s Avatar
Default Drove around all day perfectly fine. Now it won't start...HELP!
So today I drove my CRX down too my freinds house which is about 40 minutes away. I took him and our other freind on 4 different pulls on 15psi. We logged a couple runs and all were about 11.5:1AFR, and about 19degrees of timing. Pulled SOOO GOOD! NO missing, NO detonation. It was about time for work, so I packed up and started heading for home. Drove all the way too work with no problems.
I get off from work, and head out too the car....WTF. It won't start. OOOOk. Ran fine, no codes, didn't change anything?...WTF?
Car gets fuel, air, and Blue spark...yet it still won't start. Just turns over.
Any ideas?
B18C1 with OBD1 conversion P28 ECU.
Old Jan 24, 2005 | 09:01 PM
FalkenSiR's Avatar
Default Re: Drove around all day perfectly fine. Now it won't start...HELP! (Bryson)
Spark plugs damaged?
Injector (/s) messed up?
very weird indeed.
Old Jan 24, 2005 | 09:05 PM
crxhf19's Avatar
Default Re: Drove around all day perfectly fine. Now it won't start...HELP! (fast88std)
are tyou sure your main relay is working? what i am asking you is if your fuel pump turning over?
Old Jan 25, 2005 | 07:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">Spark plugs damaged?
very weird indeed.</TD></TR></TABLE>
I'm going to try a brand new set of plugs tommarow.
The ones I were running might have been fouled, but I even put in a different set, and it did the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhf19 &raquo;</TD></TR><TR><TD CLASS="quote">are tyou sure your main relay is working? what i am asking you is if your fuel pump turning over?</TD></TR></TABLE>
Main relay works since the ECU has power, and I have fuel pressure.
LSVTECTEG18
May 16, 2008 09:37 PM
*Boostwerks*
Jan 30, 2005 09:44 AM
rhl487
Sep 17, 2004 11:53 PM
