need help with installing AEM bypass valve on type R AEM CAI
Old Jan 24, 2005 | 08:01 PM
96gsrvtec1986's Avatar
Default need help with installing AEM bypass valve on type R AEM CAI
Old Jan 24, 2005 | 08:07 PM
Opie's Avatar
Ok, what's the problem?
Old Jan 24, 2005 | 08:30 PM
1GreyTeg's Avatar
Default Re: need help with installing AEM bypass valve on type R AEM CAI (96gsrvtec1986)
hacksaw
Old Jan 24, 2005 | 08:44 PM
Default Re: (opie)
where exactly would you have to cut pipe and place the bypass valve? would i have to cut some off the pipe off or something?
Old Jan 24, 2005 | 08:49 PM
1GreyTeg's Avatar
Default Re: (96gsrvtec1986)
You have to cut the pipe in half.
iirc you need to cut it closer towards the filter end, in the vertical section when it's installed, Not close to the TB. But I never went that route when I found out it lost the power it gained.
Maybe someone who cut theirs apart and installed the bypass can chime in and help this guy more.
Old Jan 24, 2005 | 11:38 PM
KayOs's Avatar
Just bypass the AEM CAI altogether
JK. Saw away.
Old Jan 25, 2005 | 06:26 AM
Bbasso's Avatar
It needs to be installed it the area I put the blue circle.
Old Jan 25, 2005 | 06:42 AM
pyromaster's Avatar
Here's how I had mine back in the day. After about a year I just put the filter where the POS bypass valve was and had it as a short ram. Besides questioning the power loss, I was also questioning how much dirt etc was coming in thru the bypass foam. If I had to do it over again, I'd go with a short ram ...if I was going to use AEM
Old Jan 25, 2005 | 08:03 AM
hYpE-R-29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96gsrvtec1986 &raquo;</TD></TR><TR><TD CLASS="quote">need help with installing AEM bypass valve on type R AEM CAI</TD></TR></TABLE>
remember to cut it in a way which you can have a AEM short Ram intake too
Old Jan 25, 2005 | 08:08 AM
1999all_motoR_teg's Avatar
Default Re: need help with installing AEM bypass valve on type R AEM CAI (hYpE-R-29)
I think the best thing to do would be to cut it where the pic above shows.
Then buy a rubber sleeve and some hose clamps and use that for regular driving. Keep the bypass valve in your car and if it starts to rain heavily pull over(where there's shelter preferably) loosen the clamp slide the rubber sleeve up the pipe and insert the bypass valve. Should take no more than 5 minutes and when the rain stops switch it back. That way you don't have to worry about rain or losing power.
Just my opinion.
prelude93si
Aug 18, 2003 01:15 PM
typer.org
Aug 6, 2003 03:23 PM
LS AnGeL
Jun 6, 2003 11:51 AM
90TegRex
Nov 17, 2002 08:06 PM
IntegGirlRacer
Aug 13, 2001 10:39 AM
