P28 to run my B18C5 in my CRX ?
I already have my crx converted to obd1 and just picked up a P28 ecu cheap. I read so much aboout people reprograming these ecu's, but truely want to know what my best option would be to do with it to run a B18C5?
Get a chip, an s100 or s200 hondata system, or perhaps uberdata? Which would be the best option, thanks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">I already have my crx converted to obd1 and just picked up a P28 ecu cheap. I read so much aboout people reprograming these ecu's, but truely want to know what my best option would be to do with it to run a B18C5?
Get a chip, an s100 or s200 hondata system, or perhaps uberdata? Which would be the best option, thanks? </TD></TR></TABLE>
I think you should run Uberdata, it's pretty much the same thing as Hondata but the program itself is FREE and all you need to buy is the equipment needed to burn chips.
If you send your ECU to http://www.moates.net you can get the BURN1 ($85), UBER1 ($15), and if you dont know how to solder ECU boards they can modify your ECU to get it Uberdata ready ($25). You can also get a Willem EPROM burner for $55 on Ebay instead of the Moates BURN1 to save yourself some money. If you have a laptop you can take that with you to the dyno facility and you'll have everything you need to tune. If you want you can also set up your ECU for datalogging and a WB.
It is pretty easy to use Uberdata and the burning software and hardware.
