Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
err...i keep forgetting....what solo2 class would I be in?
Old Jan 13, 2002 | 10:09 AM
YodaIsGod
Guest
Posts: n/a
Default err...i keep forgetting....what solo2 class would I be in?
Please help the uneducated!!! I guess they modifed some of the classes for the 2002 season
sorry fellas, i just keep forgetting. Please help me figure out what class I could be in.
00 Civic Si
i/h/e
stock cat
stock wheels with 205/50R15 RE730s
ITR Springs w/ Stock shocks (sway bars are stock 26mm front/ 13mm Rear)
full interior
If i were to install a 22mm rear sway bar, would that change my classification? I would perfer a 19mm adjustable bar instead, because my car seems to rotate just enough with the ITR springs.
one last thing....if my car were bone stock, which class does the Si belong to now?
Thanks for helping out the forgetful
Old Jan 13, 2002 | 10:23 AM
jsi's Avatar
jsi
Default Re: err...i keep forgetting....what solo2 class would I be in? (YodaIsGod)
STS or DSP
edit: in stock class it's ES i think. The swaybar is allowed in both STS and DSP
[Modified by jsi, 2:27 PM 1/13/2002]
Old Jan 13, 2002 | 10:40 AM
Solracer's Avatar
Default Re: err...i keep forgetting....what solo2 class would I be in? (jsi)
>edit: in stock class it's ES i think<
Actually it is in GS with the new stock class re-org
Old Jan 13, 2002 | 10:58 AM
MaddMatt's Avatar
Default Re: err...i keep forgetting....what solo2 class would I be in? (Solracer)
But since he's not stock, he can't play there. At least not fairly
Old Jan 13, 2002 | 11:19 AM
Honda318dx's Avatar
Default Re: err...i keep forgetting....what solo2 class would I be in? (MaddMatt)
STS if you don't have R compound tires
DSP if you do... =~)
Old Jan 13, 2002 | 10:04 PM
YodaIsGod
Guest
Posts: n/a
Default Re: err...i keep forgetting....what solo2 class would I be in? (Honda318dx)
What's DSP? Never heard of it....
BTW...what is allowed in STS when it comes to brakes? I has looking into installing some SS brakelines w/Motul fluid. Just have to decided on pads that will work great on the street and the auto-x course.
Old Jan 14, 2002 | 03:40 AM
Neo's Avatar
Neo
DSP = D street prepared -- street prepared is somewhere in the middle between the stock (S) and prepared (P) classes. Before STS was created this is where most of the "slight to moderately" prepared cars were classified. STS and DSP are somewhat similar, but DSP allows you to do a few more mods (LSD, roll cage, remove rear seat, race rubber, to name a few). DSP is a VERY competitive class at the regional and national levels...
SS brakelines are allowed in STS, so there's no problem with doing that one.
Old Jan 14, 2002 | 06:42 AM
.RJ's Avatar
.RJ
Carbotech Kelate Metallic. They're awesome.
-Ryan
Old Jan 14, 2002 | 07:02 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Default Re: err...i keep forgetting....what solo2 class would I be in? (Neo)
Can't remove back seat or interior panels for DSP....
Old Jan 14, 2002 | 07:42 AM
Neo's Avatar
Neo
Default Re: err...i keep forgetting....what solo2 class would I be in? (madhatter)
Not that I doubt you, Chris, but I would have bet $$ that it was OK in SP classes that the back seat could come out. I'll have to take your word for it given that that's where you compete. I need to go re-read the rule book Sorry for posting the wrong info.
Old Jan 14, 2002 | 07:56 AM
.RJ's Avatar
.RJ
yep, sp cars must run full interior.....
*unless* the car is prepped to IT specs, and it must run as prepped for IT. However, there are other limitations in IT that would make the car less competitive for SP autoX.
-Ryan
Old Jan 14, 2002 | 07:59 AM
Neo's Avatar
Neo
Default Re: err...i keep forgetting....what solo2 class would I be in? (Type-RJ)
-Ryan
Well then, it's official, I'm a bonehead So, where did I read that? Is it legal in SM or some other place?
Old Jan 14, 2002 | 08:13 AM
.RJ's Avatar
.RJ
Legal to remove back seat in SM, yes.
-RJ-
Old Jan 14, 2002 | 08:16 AM
CivicSiRacer's Avatar
00 Civic Si
i/h/e
stock cat
full interior
The intake, headers, ITR springs, and sway bar (rear) would throw you out of stock class (which would be GS for next year).
Better to go with STS and you can keep all your mods, and add other things.
Old Jan 14, 2002 | 08:40 AM
madhatter's Avatar
No worries...
Back seat doesn't weigh much anyway. I have pulled mine out for track days, and the whole thing couldn't weigh more than 15 lbs....and that is being generous.
Old Jan 15, 2002 | 09:44 AM
Austin's Avatar
Default Re: err...i keep forgetting....what solo2 class would I be in? (CivicSiRacer)
What type of mods are allowed to keep mister Yoda in STS?
Austin
Old Jan 15, 2002 | 11:06 AM
Default Re: err...i keep forgetting....what solo2 class would I be in? (Austin)
For STS:
intake
catback exhaust
headers
suspension which attaches to OEM points
Polyurethane bushings
sway bars
strut bars
wheels up to 7.5" wide
tires up to 225 wide and 140 minimum tread wear
short shifters
must have stock interior
front seats have to recline
removal of A/C and powersteering allowed
Spark plugs
Spark plug wires
Aftermarket pulleys
body kits
brake pads
brake rotors OEM sized
stainless steel brake lines
piggy back ECUs are legal
NO IGNITION AMPLIFIERS
NO AFTERMARKET LSD unless on excursion list (Sentra SER, 2.5RS)
CARBON FIBER PIECES ARE ILLEGAL
CAMS, CAMSHAFT OR ANY INTERNAL ENGINE WORK IS ILLEGAL
Forced induction is legal if you are on the excursion list (Audi/VW 1.8T FWD, Mazda 323 GTX (turbo AWD))
I missed some things but you get the gist.
[Modified by CivicSiRacer, 3:08 PM 1/15/2002]
Old Jan 15, 2002 | 11:36 AM
WRXRacer111's Avatar
Isn't the removal of A/C only allowed if it was optional on the vehicle? IE, I could remove the A/C on my Integra RS b/c it was an option, but A/C could not be removed from a GS-R b/c it is part of the trim level package?
Hmm... Interesting to know that with 10lbs. wheels and dumped A/C, that would've put my Integra at 2360 pounds. Not bad for full interior otherwise.
Old Jan 16, 2002 | 04:43 AM
Default Re: err...i keep forgetting....what solo2 class would I be in? (WRXRacer111)
If I read the rules right they allow it for any car - cause most drag racers take them out.
dfoxengr
27
Jan 7, 2008 05:36 AM
skierd
Mid-Atlantic (Sales)
Jul 6, 2007 04:33 AM
SJR
Mar 26, 2003 09:14 AM
bocian
Mar 27, 2002 09:13 AM
