Radius Rod Replacement
From: Murfreesboro, Tennessee, United States of America
hey i got in a bad wreak a few weeks ago and am now putting my crx back together i was in the middle of putting on a new driver sider axle and suspension when i saw that my radius rod was cracked i was just wanting to know can i fix this with the full suspenion on or should i just wait till i can get a new one?
also where can i get a new or good used on for cheap?
you should be able too, jsut undo the bolt on the crosmember, then unbolt the rod from the control arm, you should be able to work it out then install a new one
to install it id line it up in the hole onto crossmember then bolt it down to the lca.
redman223
May 17, 2007 07:19 PM
