eg and ek inter changealbe ?
i want to know if the mount are the save for ek and eg motor wise and ac unit wise let me know thanks. driver , tranny and l-braket all the same mount and will 96 civic a/c unit fit a 92-95 civic thanks
If your putting in a b series motor, you will need integra and your stock mounts. As far as the ac is concerned, the bracket may bolt up I'm not sure, but I know that the lines are different between the years, so you'll have to get custom ends made up... try searching for some information, this topic has been covered a million times
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n2civicsi »</TD></TR><TR><TD CLASS="quote">this is for sohc motor not b-series</TD></TR></TABLE>It really doesn't matter, the motor is OBD2 and the car is OBD1.... the ac unit won't bolt up to the lines that run along the rad support. As far as mounts go I don't know...
BoostedH
Jan 20, 2008 10:10 AM
DFW
15
Feb 13, 2007 08:11 PM
FritzInTN
Jan 20, 2004 02:51 PM
