What Amp Should I Use?
I currently have 2 12" Rockford Fostgate RFP4412 subwoofers but I am not sure what kind of amp I should hook them up to. When it comes to car audio, I don't know nothing. Here are the specs on the subs:
Nominal Power Handling - 200 Watt
Peak Power Handling - 400 Watt
Frequency Respond - 28 Hz - 400 Hz
Sensitivity - 88 dB
Impedance - 4 ohm
Woofer Material - Poly / Plastic
Surround Material- Foam
Enclosure- Non-Enclosed
Top Mounting Depth- 5.75 In.
Thanks, I would really appreciate it.
Sensitivity - 88 dB
Impedance - 4 ohm
iiPancho
Audio / Security / Video
13
Jan 2, 2010 01:29 PM
FBP Si 2000
Dec 18, 2003 02:05 AM
