help on teg signal light wiring
Old Jan 24, 2005 | 09:44 AM
alfee's Avatar
Default help on teg signal light wiring
alright, i've tried searching and found nothing. maybe my keywords are off but anyways. heres the problem, my front corner/signal lights weren't working on my 95 teg so i put a set of 99 signal light wiring on it. just matched up all the colors of the wires. but it seems that all 4 wires match up except for a RED wire and a Green wire. there was nothing else to connect those two to, so i just connected them together. i turned on my parking lights and the little bulb came on. did a signal check and the bigger bulb blinked. somehow it looks funny because the big blinker light does not turn on when my parking lights are on. so if you look at the car from the front view, you only see the side part of the signal lamp on whereas the front face of the lamp is dim unless you're signaling then it'll blink . can someone shed some light on this for me?
mikecp
Jan 20, 2020 02:19 PM
dc2driver408
Aug 15, 2010 07:03 PM
a2dadamm
Lighting
Feb 2, 2008 11:40 AM
sk!tz0
Jul 16, 2003 07:28 AM
MTR.18
Jan 18, 2003 01:04 PM
