Full gsr swap for sale w/ extras
1997 legit ls block, je turbo pistons, eagle H-beam rods, arp rod bolts, all new act bearings, new rings, hot tanked, honed out, fully balanced and blue printed bottom end, needs pumps, oil pan and girlde, ZERO miles since the built $1400
1996 gsr block 70-75k very clean, its complete from top to bottom & LEGIT*
1998 gsr head, milled over, ferrea valves, stock springs and cams, ti-retainers, 3 angle valve job, port and polished ZERO miles on it since build
2000 si transmission 23k MINT no grinds what so ever
Comp-tech header
Skunk 2 racing chipped p28 ecu
New exedy pressure plate
Brand new ACT street disc
Brand new distributor
Brand new gsr axles
Hasport Linkage w/ short shifter and urethayne bushings
Brand new in boxes Hasport motor mounts your choice of ek or eg
Brand new Gsr head gasket in wrapping from acura
Brand new Intake manifold gasket from acura
Brand new timing belt from acura
**Online sites what $3550+ for a full bone stock gsr swap, i want $3300 for all the extras listed half of it has never even been used**
Modified by widebodyjaeg16b at 1:45 PM 1/24/2005
Modified by widebodyjaeg16b at 2:00 PM 1/24/2005
Comp-tech header
Brand new gsr axles
Devers
May 20, 2013 08:31 PM
