eg hatch front lip on 4 door.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek9ReVciVic »</TD></TR><TR><TD CLASS="quote">does the eg hatch stock front lip fit on a 4 door eg..??
if not is there any way to use it on the 4 door....</TD></TR></TABLE>
im sure there is a way to make it fit...i doubt its a direct bolt up for the single reason the front bumpers are different....people are always trying to make different year lips fit on different bumpers give it a try and post it up....also try doing a search i found this one thread hope it helps...then again i saw in another one someone said it will not work....
https://honda-tech.com/zerothread?id=232893
people have done 99-00 civic si front lips on their 92-95 civic...so eg hatch front lip on a 4dr wouldn't be any different i suppose. they are different in the end.
the oem eg coupe/hb lip is about a half inch too short on each side although it can be made to fit......what i did was use screws that sat flush with the lip, no one ever noticed but then i was able to find a ferio front lip and it bolts up perfect
do a search under my screenname in the archives and you'll see pics
jme4130
Apr 3, 2005 03:09 PM
WHATS VTEC
Aug 6, 2003 08:40 AM
