ZC swap problems.
i just swaped a zc engine on my crx si and when i raced it first gear was alright but once i switched to second gear the RPM stayed at 6000rpm it wont like start again from like 4000rpm would it be something with the clutch cause its a racing clutch. how can i fix it?
2 things, did you resurface the flywheel or replace the clutch when you put it in? If not get a new clutch and get the flywheel resurfaced, and make sure you replace the throwout and pilot bering while your in there.
Creepshow S60
Nov 11, 2004 10:32 AM
