Need Help from the honda gurus
Old Jan 24, 2005 | 08:44 AM
Bull_head360's Avatar
Default Need Help from the honda gurus
I start my car up, no CEL, it warms up, rpms drop, after awhile CEL comes on. shut off and restart motor, no CEL, let it idle for awhile, comes back on, so i tested it with the motor running and this is what i got...also my redline seems to be at 7500rpm no matter if the CEL is on or off, what could be causing that?? 94 b18c1 with (as far as I know) stock p72. Anyone know whats going on? I understand the code 8, but I dont know what code 41 means...any help would be nice! Thanks
8 TDC - top dead centre sensor
41 Primary oxygen sensor heater
Old Jan 24, 2005 | 09:22 AM
JimBlake's Avatar
Default Re: Need Help from the honda gurus (Bull_head360)
The O2 sensor has a built-in preheater. Check the 2 same-color wires on the sensor. They should measure 10 to 40 ohms between them, & neither one should have any continuity to ground. If that's not OK, buy a new O2 sensor.
If that's OK, then you gotta look for shorts or opens in the car's wiring for this circuit.
Old Jan 24, 2005 | 12:55 PM
what does the pre-heater do? heat the sensor? i live in florida and it got down to 28 degrees last night, (coldest night/day this season) would that have anything to do with it?
Old Jan 24, 2005 | 01:04 PM
JimBlake's Avatar
Default Re: (Bull_head360)
no, the sensor needs to get up to maybe 1500 deg.F before it starts working. Back in the late 70's the sensors were simply heated by the exhaust after a couple minutes. With a preheater they come up to working temperature in probably less than a minute. EPA rules...
Old Jan 24, 2005 | 04:44 PM
jebus, thats hott y0! other people are telling me that the rpm thing sounds like i need a new distributor, whut do u guys think?
Old Jan 24, 2005 | 04:53 PM
Racermech's Avatar
I thought the rpm was limited to 7700??
Old Jan 24, 2005 | 06:16 PM
no, stock gsr redline is 8100rpm
Old Jan 24, 2005 | 06:27 PM
blkb18's Avatar
the top dead center sensor is in the distributor and is not available seperatly. The tach also uses one of the sensors in the dist for its signal, maybe the tdc sensor is %#$@# up.
Old Jan 24, 2005 | 07:17 PM
LSTEG96's Avatar
Default Re: Need Help from the honda gurus (blkb18)
1500 degrees F? holy ****. aluminum melts at 1400.................
Old Jan 25, 2005 | 04:01 AM
JimBlake's Avatar
Default Re: Need Help from the honda gurus (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">1500 degrees F? holy ****. aluminum melts at 1400.................</TD></TR></TABLE>I was sorta guessing, maybe that's high. But the sensing element has to get way hotter than the exhaust pipe metal. The aluminum (exhaust ports in the head) are kept cool by their water jacket. Those surfaces never get nearly as hot as the exhaust gas temperature.
Old Jan 25, 2005 | 04:19 AM
campbuds's Avatar
check the wires to you O2 and make sure the plug isn't pulling apart.
i would also check the timing, the belt may have jumped.
Old Jan 25, 2005 | 04:20 PM
Default Re: (campbuds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">the top dead center sensor is in the distributor and is not available seperatly. The tach also uses one of the sensors in the dist for its signal, maybe the tdc sensor is %#$@# up. </TD></TR></TABLE> this sounds like the culprit...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by campbuds &raquo;</TD></TR><TR><TD CLASS="quote">check the wires to you O2 and make sure the plug isn't pulling apart. i would also check the timing, the belt may have jumped.</TD></TR></TABLE> i messed with the o2 sensor the other day, and everything looked good as far as i could tell...drove the car for a good hour today, running errands, no CEL...i guess i'll replace the distributor, cap and rotor, etc. and check the timing...we'll see whut this does, thanks guys, if i still have problem, i'll be back...now i just have to find the time to do this
Boosted97Ej8
12
Oct 8, 2012 12:04 PM
97civic07gsxr
Mar 27, 2009 05:11 PM
sadangryboi
May 10, 2005 02:03 PM
nwarp
Jul 17, 2004 06:01 PM
