WHAT should I do???????????????????
Old Jan 24, 2005 | 08:42 AM
RussHondaCRX's Avatar
Default WHAT should I do???????????????????
I have low compression in one of my cylinders i have 220-210-180-210 I was thinking of a new bottom end I just need some thoughts and some Ideas of what I should do
Old Jan 24, 2005 | 09:25 AM
mrspeaker's Avatar
Default Re: WHAT should I do??????????????????? (RussHondaCRX)
What motor do you have that its like that?..
My old hatch(d15b2) was 180-182-185-182..
Old Jan 24, 2005 | 09:26 AM
FalkenSiR's Avatar
Why would you think a new bottom end would increase your compression?
imo what id think is a bent valve, because it isn't even across all cylinders...
Old Jan 24, 2005 | 09:28 AM
RCautoworks's Avatar
Default Re: WHAT should I do??????????????????? (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">
imo what id think is a bent valve, because it isn't even across all cylinders...</TD></TR></TABLE>
It could still be a bad headgasket or rings. But your right, you can't tell unless you do a wet test or a leak down test.
Old Jan 24, 2005 | 10:16 AM
91civicEX's Avatar
thats not that bad. do a leakdown test to see if its the top or bottom end. i think the rule is that the lowest reading should be within 75% of the highest. not sure on precent. so .75x220= 165 that means your safe. does the car run rough?
JFG Kevin
Jul 19, 2006 07:49 PM
vietdragontekx
Apr 21, 2006 04:30 AM
allmotorsi04
Apr 1, 2006 05:08 PM
RussHondaCRX
Jan 26, 2005 08:42 AM
fastfu
Jun 30, 2004 11:59 AM
