Hesitating ZC
Old Jan 24, 2005 | 05:55 AM
tpr's Avatar
tpr
Default Hesitating ZC
Just as it says my ZC with 91 SI ECU has been working fine till about a month ago. Now when it is cold the just off idle response is delayed. I have checked for vacuum leaks and found none. When the engine warms up it becomes less noticeable. above part throttle it seems to work fine cold or warm. Any ideas?
Old Jan 24, 2005 | 07:01 AM
HumanResource's Avatar
Default Re: Hesitating ZC (tpr)
Trying adjusting TPS, but before that try the usual things
OCTANE and Timing
Ignition related components (Dist Cap/Rotor, wires and plugs)
Old Jan 24, 2005 | 07:42 AM
crxgator's Avatar
Default Re: Hesitating ZC (HumanResource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">Trying adjusting TPS, but before that try the usual things
OCTANE and Timing
Ignition related components (Dist Cap/Rotor, wires and plugs)</TD></TR></TABLE>
also get a different ecu, the pm6 is horrible for the zc, get a 88-89 teg PG7...
90crxdohczc
27
Apr 14, 2006 03:55 PM
SwissChEz82
10
Apr 20, 2005 07:22 PM
grover
Aug 20, 2004 08:28 PM
