axel help
Old Jan 24, 2005 | 05:26 AM
sockvtec's Avatar
Default axel help
ok i got t-boned, messed my passesnger side up (pics in sig)...i know my axel is meesed up and i searched and found this https://honda-tech.com/zerothread?id=382416
i want to do this, but im not sure if my lca, uca, or tie rod or any of that stuff is messed up, how can i tell if any of that stuff is messed up...and another thing, how much does a new axel cost...i pretty sure i only need that one side, but i dont know how much thay cost so any help is appreciated
*edit* i have drove on the axel for about 800 miles now becuase i have to commute to college, how much longer can i go before it like snaps off or something?
Old Jan 24, 2005 | 06:39 AM
sockvtec's Avatar
Default Re: axel help (zoomzoom92)
anybody????
Old Jan 24, 2005 | 07:12 AM
sockvtec's Avatar
i need some help people
Old Jan 24, 2005 | 07:14 AM
Slopoke's Avatar
A new axles usually cost around $50-$70.
How long your axle will last just depends on how bad of shape it is in.
You could crawl under the car and see if there is any obvious damage to the suspension on that side.
You could also take it in for an alignment. The will beable to tell if things are really out of whack.
Old Jan 24, 2005 | 11:01 AM
sockvtec's Avatar
Default Re: axel help (Slopoke)
ok thanks, any other suggestions guys...anybody else had to go through this?
Old Jan 24, 2005 | 11:46 AM
94eg!'s Avatar
#1 Super Guy
Loved
Does the car still drive the same after the acident? If your suspension got damaged, either the car won't track straight anymore, or bump steer will be funky.
I buy axles from autozone. $60 w/ a lifetime warranty. You also need to rent a 32mm socket for your breaker bar. Make sure the new axle comes with a new hub nut because you don't want to reuse the old one once it's been staked down.
I browsed that DIY thread & I have a few at home tips:
Remove the hub nut before you remove the wheel & jack up the car when not using an impact gun
Use the 1/2" rachet method to seperate the lower balljoint from the LCA:
***jack up LCA
***place rachet handle on its side (tall way) next to balljoint boot
***lower the jack under the LCA & remove (rachet handle should bind up next to balljoint)
***push down on brake rotor until rachet handle pops balljoint free
Reassembly:
Put the lower balljoint into the LCA so the stud is sticking out the other side
With the car on jackstands, place your jack under the LCA
Jack up LCA until car starts to lift
Have someone push down on Brake rotor w/ all their weight as you torque castle nut (helps to keep the balljoint from turning)
Old Jan 24, 2005 | 01:15 PM
sockvtec's Avatar
Default Re: axel help (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Does the car still drive the same after the acident? If your suspension got damaged, either the car won't track straight anymore, or bump steer will be funky.
the car drives fine, but it bent my wheel in like i have negative camber, and the steering wheel is cocked to the right (when i have the wheels straight, the steering wheel is turned to the right...probably about 1oclock) so i dont know if its just my axle or other suspension stuff
Old Jan 24, 2005 | 02:30 PM
sockvtec's Avatar
any ideas whats wrong?
Old Jan 24, 2005 | 04:23 PM
sockvtec's Avatar
Old Jan 24, 2005 | 05:08 PM
sockvtec's Avatar
come on guys, help me out
Old Jan 24, 2005 | 06:48 PM
sockvtec's Avatar
Old Jan 25, 2005 | 10:44 AM
sockvtec's Avatar
anybody know whats wrong?
Old Jan 25, 2005 | 01:53 PM
Slopoke's Avatar
Well, if the top of your wheel is tilted in, your upper control arm is probably f*cked.
There's also a good chance your knuckle is messed up too.
I hit a curb a few years ago and I had to replace upper control arm, lower control arm, knuckle, and steering rack.
Unless you just want to guess and start replacing things one by one, you should take it somewhere and have them tell you exaclty what is wrong.
Old Jan 25, 2005 | 03:44 PM
sockvtec's Avatar
ok thanks man
EFjoe91
Transmission & Drivetrain
Jan 10, 2013 07:06 AM
Turbo-charged
Jun 24, 2006 10:48 AM
Humlae
Jun 6, 2004 12:51 PM
gumbybum
Jan 26, 2003 06:16 PM
jadedasn
Oct 30, 2001 10:43 PM
