weird noise when i turn right!! HELP
Old Jan 23, 2005 | 08:25 PM
veilsides2000's Avatar
Default weird noise when i turn right!! HELP
It all started yesterday!!! i have no idea to what it might be or how it even started. But everytime i take a right turn, kind of a sahrp turn i hear this grinding noise come from my front driverside wheel. i thought it maybe something that is hitting theground because the car is lowered but it only does it when i turn right. i looked under the car nothing hanging loose. please any help would be greatly appreciated
Old Jan 23, 2005 | 09:45 PM
DC2tuner's Avatar
I Think I'm TOO White For This Thread
Default Re: weird noise when i turn right!! HELP (veilsides2000)
prob. ur rims r rubbing on the body
Old Jan 24, 2005 | 02:02 AM
LsVtec98's Avatar
did you check for wear on your tire at all? could possibly be your cv joints, but prolly want to check everything else before taking that road...
Old Jan 24, 2005 | 03:49 AM
TurboEH2's Avatar
Default Re: (LsVtec98)
could be your brakes also
Old Jan 24, 2005 | 05:28 AM
Default Re: (LSturboEH2)
like my brakes are rubbing against my rims??
Old Jan 24, 2005 | 06:09 AM
Ldc4S's Avatar
Might be your cv joint if its grinding loud. Same thing happened to me.
Old Jan 24, 2005 | 08:40 AM
TurboEH2's Avatar
Default Re: (veilsides2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veilsides2000 &raquo;</TD></TR><TR><TD CLASS="quote">like my brakes are rubbing against my rims??</TD></TR></TABLE>
no, like ur brakes are grinding cause the pads need to be changed. once they get so bad the rotors can become fucked also. but if it just sarted id look over the brakes see if u can see a groove or if the pad is excessivly worn, most cv problems i have had was a click, but they could grind. id pull the wheel off and just give everything a once over.
Old Jan 24, 2005 | 09:34 AM
cnydc2's Avatar
Check the brakes, and take the rim off and see if there are any places where the paint and under coating was rubbed off. If there is your tire is rubbing your body. What size are your wheels? I still think that the griniding is your brakes.
uschonda
Mar 12, 2007 02:02 AM
erikiksaz1
Sep 13, 2004 06:00 PM
es_squared
Jun 24, 2004 01:35 AM
90-CRXSi
Jun 21, 2004 12:39 PM
bwan24
May 25, 2003 01:07 PM
