tranny ?
Old Jan 23, 2005 | 07:27 PM
baddog's Avatar
Default tranny ?
i have a 94 integra ls with a 1.8L. what tranny will fit in this car. (man. tranny). mine took a ****. will the 2.0L prelude tranny fit?
Old Jan 23, 2005 | 07:40 PM
IN VTEC's Avatar
Default Re: tranny ? (baddog)
What's wrong with your original transmission? They're easy to rebuild if you can afford the parts (depending on what needs replacing) and have a few extra tools.
A Prelude tranny will not bolt onto a B-series engine. You need another B-series transmission of the same clutch actuation type (hydraulic in your case). a '94-'00 Integra LS tranny would probably be the cheapest one.
Old Jan 23, 2005 | 07:45 PM
eluam's Avatar
Default Re: tranny ? (IN VTEC)
B16, LS, GSR, ITR...take your pick.
Old Jan 23, 2005 | 08:19 PM
93tegy's Avatar
Would you happen to know were to get the parts to rebuild one?
thanks
Old Jan 23, 2005 | 08:20 PM
chero112's Avatar
Default Re: tranny ? (geeZus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geeZus &raquo;</TD></TR><TR><TD CLASS="quote">B16, LS, GSR, ITR...take your pick.</TD></TR></TABLE>
Try to just get your tranny fixed, or just buy a b16 or gsr for around 500 dollars
Old Jan 23, 2005 | 08:30 PM
Marauder's Avatar
Default Re: tranny ? (93tegy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93tegy &raquo;</TD></TR><TR><TD CLASS="quote">Would you happen to know were to get the parts to rebuild one?
I sell parts for rebuilding transmissions thru Gear Speed. Just let me know what parts you need and you can compare to other places.
Old Jan 23, 2005 | 09:08 PM
93tegy's Avatar
Default Re: tranny ? (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">
I sell parts for rebuilding transmissions thru Gear Speed. Just let me know what parts you need and you can compare to other places.</TD></TR></TABLE>
I need a whole rebuild kit i guess.Im not sure i dont have 4th or 5th gear and i would rather just rebuild the whole thing. Think you could give me a price?? Its for a 93 integra ls
Old Jan 23, 2005 | 09:57 PM
1320lsvtec's Avatar
are u able to change the gear ratio, when u rebuild a tranny? cus the ls trnny's have long gears...and if u can change the ratio, will it be cheaoer than an si, or gsr ???
Old Jan 23, 2005 | 11:08 PM
Bk2fwd's Avatar
how would a LS run if a itr tranny was bolted up to it? has anyone done this?
Old Jan 24, 2005 | 06:18 PM
93tegy's Avatar
I cant pm peps so if you see this plz respond.thx
jfrase06
13
May 17, 2007 09:00 PM
jokr78
Apr 17, 2005 02:54 PM
righteyeblind
Nov 21, 2003 03:15 PM
civicdream
Apr 14, 2003 06:51 PM
