90 teg with b16a Mount problems.
Old Jan 23, 2005 | 07:19 PM
bossman032's Avatar
Default 90 teg with b16a Mount problems.
hey guys,
I am swaping my teg 90 with a b16a I am having mount problems.
what company makes mounts for my year..??
What mounts do I need to swap the b16a in my teg..
thanks
Old Jan 23, 2005 | 08:17 PM
DoctorGSR's Avatar
Default Re: 90 teg with b16a Mount problems. (bossman032)
your stock mounts will work with the b16
Old Jan 23, 2005 | 08:45 PM
SpoolnG2's Avatar
Default Re: 90 teg with b16a Mount problems. (QuikLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuikLS &raquo;</TD></TR><TR><TD CLASS="quote">your stock mounts will work with the b16</TD></TR></TABLE>
Old Jan 23, 2005 | 08:55 PM
bossman032's Avatar
Default Re: 90 teg with b16a Mount problems. (SpoolnG2)
are you guys sure cause the front mount on the cross member is hitting the tranny.
also the header is hitting the cross member..
which way do I have to drop the mounts in tranny side first then L bracket then driver side..
man I am pissed
Old Jan 23, 2005 | 09:41 PM
notstock93's Avatar
?hat header are you using? 4-1 headers will almost always hit the crossmember on DA's. You have to notch the crossmember to make enough room for the header.
Stock mounts work. Im using them in my B16 Teg.
Old Jan 24, 2005 | 10:03 AM
DoctorGSR's Avatar
you dont need the front mount. and yes, most 4-1 headers will hit the cross member. get a 4-2-1. lower the tranny side in first.
Old Jan 24, 2005 | 10:18 AM
jDMJeRk's Avatar
I JUST did my swap and it was a jdm b16 and i used my stock b18 mounts with some inserts and some urethane... got all four mouts on just fine w/o problems...
Im also running a fullrace crossmember but a 4-2-1 header and didnt have any clearance issues; although that is one of the reasons fullrace made the members for DA's
hths!
BTW the rear mount SUCKS putting on
bigD
Jan 9, 2008 07:28 PM
tallkan
May 6, 2007 11:28 AM
89 CRX SI
16
May 1, 2002 09:27 PM
90CIVICSI
Jan 15, 2002 08:17 PM
BigBlockCRX
10
Dec 30, 2001 07:42 PM
