cel after seafoam
Old Jan 23, 2005 | 03:32 PM
chjkingme's Avatar
Default cel after seafoam
ok, i put sea foam in my 96 ls this afternoon and started getting the cel. im assuming this is the o2 sensor, but i was planning to pull the fuse on my ecu first and see if by chance that resolves the problem. now i run into another problem: i don't have the code for my stock cd player, and to get it i must call the acura dealer who is not open on sundays. my question is whether or not it is a bad idea to keep driving around with the cel staring me in the face? is the o2 sensor going to mess with my engine? i must say the sea foam did a nice job, but i'd rather not mess up the whole thing even though i need the car for work tomorrow. any help is much appreciated.
Old Jan 23, 2005 | 04:37 PM
97Alex's Avatar
Default Re: cel after seafoam (chjkingme)
wow nobody replied to this yet??!?
Pull the code to find out what the CEL is. If o2 sensor is the code then yeah go ahead and drive it...
Old Jan 23, 2005 | 05:50 PM
3.504's Avatar
Default Re: cel after seafoam (97Alex)
you'll run open loop thats all, its ok to drive like this unless theres mechanical problems. iyou might have some driveability problems (like stutter) but i doubt it. ts a 96 LS so you'll need a scanner to pull code, go to autozone, they'll do it for free. after you find code, replace what you burnt up with the seafoam. dont try that crap again.
Old Jan 23, 2005 | 06:28 PM
chjkingme's Avatar
Default Re: cel after seafoam (3.504)
haha i liked the sea foam but i think i'll pull the o2 first next time. hey thanks for the help though, i'm glad i'm not stuck tomorrow.
Old Jan 24, 2005 | 10:49 PM
aznxenon's Avatar
I'd seafoam'd 2 of my cars and 2 of my friends' cars. It's really weird how I didn't get CEL on both my cars but CEL on both his cars. On his Integra, it went away on its own after a week of driving, but on his Accord, it stayed on for a while (but now the car it totalled so I don't know if it ever went off or not).
Old Jan 25, 2005 | 05:23 AM
95lstegman's Avatar
Default Re: cel after seafoam (aznxenon)
i've never heard of this. i would do it to my car if i hadn't just had the head off and all, but i'm thinking of using seafoam on my g/f's car. now i don't know if i want to use it . . .
Old Jan 25, 2005 | 07:23 AM
TayTeg91's Avatar
Default Re: cel after seafoam (95lstegman)
did you use it right? Mine worked fine just looked like i was cheech and chong going down the road for a while with all the smoke
Old Jan 25, 2005 | 09:28 AM
blacknbean's Avatar
Default Re: cel after seafoam (TayTeg117)
i hear its possible for seafoam to foul up your spark plugs and maybe o2 sensors..if your cel is from your o2 sensor i would take it out and clean it with some brake cleaner or something and try it again
Old Jan 25, 2005 | 11:16 AM
LSvtec03's Avatar
Default Re: cel after seafoam (blacknbean)
why not actually check the code instead of guessing what it is and assuming you're right?
Old Jan 25, 2005 | 03:06 PM
rough_draft's Avatar
i sea foamed my gsr. worked wonderful.
Old Jan 25, 2005 | 03:20 PM
DarkDragon's Avatar
Default Re: (Lmaonade)
how exactly do u induce it into the engine? a few people on mx6.com when i have my mx6 did it to there cars and they used the brake booster vacume hose. will any vacume hose work or what. As for the cel like everyone else said pull the code and also check plugs see if they need changing
Old Jan 25, 2005 | 03:36 PM
Default Re: (DarkDragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkDragon &raquo;</TD></TR><TR><TD CLASS="quote">how exactly do u induce it into the engine? a few people on mx6.com when i have my mx6 did it to there cars and they used the brake booster vacume hose. will any vacume hose work or what. As for the cel like everyone else said pull the code and also check plugs see if they need changing</TD></TR></TABLE>
put some in ur gas tank, some in the oil crank case, and then into a vacuum hose. there is an article here on h-t that tells you step by step.
Old Jan 25, 2005 | 04:36 PM
alotawatts's Avatar
You must have done the manifold ?. I got a CEL when I Seafoamed mine. I never did check the code. Odds are it was a misfire and not the O2 sensor. Pull your backup fuse or battery NEG cable and clear it. You should be fine.
Modified by alotawatts at 5:49 PM 1/25/2005
Modified by alotawatts at 8:28 AM 1/26/2005
Modified by alotawatts at 8:29 AM 1/26/2005
Old Jan 25, 2005 | 07:26 PM
chjkingme's Avatar
Default Re: cel after seafoam (alotawatts)
well i checked the code and apparently it was my speed sensor....confuses the hell out of me, because i haven't had any problems with speedo or mileage goin weird on me. i didn't get to finish messing with it because i did it during lunch at the shop at work, but tomorrow i'll erase the code and see what happens...maybe it did just misfire and throw a weird code at me....uh....GO SEAFOAM lol
Old Jan 29, 2005 | 10:50 AM
3.504's Avatar
vss is a funny code to come up, i'd clear it and see if it comes back.
91hatchproject
Mar 29, 2010 04:40 PM
undertheradar
Dec 4, 2004 08:03 AM
terminaloverlowd
Oct 1, 2004 09:03 AM
tonezilla
May 18, 2004 02:19 AM
MintyDip
Jan 21, 2002 09:37 AM
