Eibach sway bar doesnt fit 2000 si. Help?
I recently purchased the Eibach anti roll kit for my 2000 honda civic si. The kit consists of a front, and rear sway bar, and provided hardwear. The rear sway bar fit with no troubles, but as I was about to install the front bar I noticed my factory bar has horizontal mounting points "the bolt goes in the side of the bar." The Eibach front bar mounts vertically "bolts go in top to bottom." The problem is the end links Eibach sent wont fit the lower control arm, and the sway bar at the same time. What they sent looks like a straight bolt, and the oem end links have a z shape. I contacted Tire Rack "where I got the kit from." They advised me that I must have a special limited production Si made in Canada, and I would have to go to Acura and get end links from a 2001 acura integra. I am going to try to contact Eibach tomorrow for more information. If anyone has experienced this problem before, and has a solution, please help. Thanks.
dgdarien
10
Mar 30, 2003 01:09 PM
ichibano
11
Feb 14, 2003 02:56 PM
