Resleeve ls block to 85mm for ls turbo.. Good idea??
Im plannin to send out one of my cracked ls block to get it resleeve. I want to bore it out to 85. mm and most likely gonna get me some je pistons and eagle rods.. U guys think its safe if i bore it out all the way to 85?? i want more torque and boost. I want to boost all day and the engine wont blow.. U think 85 can handle that kind of pressure?
1997 dc2 Turbo
1997 dc2 Turbo
I have mine sleeved to 84.5 and its fine. As long as you use high-quality sleeves it wont be an issue.
I was told though 84.5 is probably the max to go for b18b1. If you had a B20, then u could go with a 86.5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsvtecBoi408 »</TD></TR><TR><TD CLASS="quote">Im plannin to send out one of my cracked ls block to get it resleeve. I want to bore it out to 85. mm and most likely gonna get me some je pistons and eagle rods.. U guys think its safe if i bore it out all the way to 85?? i want more torque and boost. I want to boost all day and the engine wont blow.. U think 85 can handle that kind of pressure?
1997 dc2 Turbo</TD></TR></TABLE>
there are a lot of good sleeving companys out there...just search in the forced induction forum....benson, golden eagle, darton, aebs, ect ect
personally id go 84 mm just in case if i had to go back in for some reason
If i were to sleeve my motor 83mm would be the best since if something happen you can bore it out, If you going with 85mm and something happen consider is gone. The different wont be that big either so it not worth it
largest i'd go is 84.5 on any b-series. b20's are b18 blocks with the stock sleeves punched to 84. service limits on stock b-sleeves is 84.5 even if its a b20. some aftermarket performance sleeves claim 86-86.5mm. i dont trust out that far especially with boost simply for strength and overheating issues.
i'd say 84 or 84.5 is your best bet
if i bored it out to 84.5 will i feel the difference? Im plannin to boost up to either 11 psi or 12.... U think its worth it to bore it out to 84.5?? get me je pistons, eagle rods?? u think with that setup will make me feel the difference???
boring to 84.5 on stock sleeves brings down lifespan and reliability so much. theres too many factors to say if you'll feel a difference. a rod/piston motor you could get more than 11-12 lbs out of the motor reliably and you will notice a difference from that. i'd be more concentrated on pistons and rods than boring stock sleeves to 84.5.
so i should just buy je pistons and eagle rods instead, of wasting my money on gettin it bore out?
So what your trying to say is boring out my block kill my engine faster?
It wont be reliable as much as a stock block?
I thought it helps your motor to run stronger, and more reliable...
Questions regarding woudl u feel a difference?
Well before i had 84.5 mm I woudl hit around 160ft/lb of tq at 4k. Now its nearly 190ft/lb
All on 8psi and a T3/T04E 57 Trim .63A/R turbine.
So i'd say it makes a diff from 81 - 84.5 in the TQ area
aight, thanks a lot guys..
boring out my block to 84mm
Getting.. eagle rods, je pistons, and most likely some new valve springs and retainers. Also picking up a port and polished ls head..
My turbo set up.. t-3 t-4 , 310 injectors, fmu , cooling fan, hks manifold, hks innercooler, 3.0 piping, hks blow of valve. gsr oil pump gsr water pump.
stock cams stock cam gears.
Once i get my whole set up in.. How much u guys think im gonna be pushiing?
Im trying to hit at least in the 11 sec range.. hope that setup get me in the 11 secs range...
hmmmm, 11 seconds??? i dont think u'll hit 11's with that settup. maybe if u up the boost a bit and strip the car. maybe 13's and 12's with higher boost and good tuning
no way. lol
13's are attainable with an 8psi setup on a fairly decent sized turbo and good tuning. (full body full interior).
Most of those greddy kits n **** run low 14's
11's aren't likely on this type of setup. throw some 880cc injectors and a hondata into the mix and now were talking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsvtecBoi408 »</TD></TR><TR><TD CLASS="quote">aight, thanks a lot guys..
injectors are to small if your going to hit 11's and your damn sure not going to do it on fmu. i with t3mp3st get some 880's and some sort of standalone i/e hondata or chip programs such as uberdata or crome
</TD></TR></TABLE>injectors are to small if your going to hit 11's and your damn sure not going to do it on fmu. i with t3mp3st get some 880's and some sort of standalone i/e hondata or chip programs such as uberdata or crome
yeah bigger injectors im gonna get for sure.. and honda i will once i get pay for the next pay check.. I got a problem too.. My car is running on a missing link, and i think its ******* up my car because everytime i drive normal like trying to shift at like 3 on first gear... My car woudlnt wanna go.. It just hella lagg on me, i have to hella step on the gas and wait for it to go faster. When it was stock that never happen.. now turbo came in whenever i shift to 2 or 3 or 4 or 5 gears.. my car wouldnt wanna go, **** lagg more than stock..
have this happen to any of u guys...
got a solution that would solve this??
nickgmiller04
12
Mar 26, 2004 04:07 PM
