Heater Problem & it's darn COLD!
Car:
93 Civic CX
Problem:
For some reason, my car only blows hot air when revved at about 2k or while im driving. The thermostat is practically new if it matters, did it about 5k miles ago along with the swap.
Insight?
93 Civic CX
Problem:
Insight?
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
question: which thermostat did you buy? ie. from where? what is the temp guage reading?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney »</TD></TR><TR><TD CLASS="quote">pm sent
tks for your help. Anyone else?
</TD></TR></TABLE>tks for your help. Anyone else?
signs of a bad heater core: The smell from your vents would be sweet smelling...kinda odd...but if you've noticed it, then your core's probably going bad. Honda heater cores aren't really known to go bad so i'd check to make sure the thermostat hasn't gone bad already. Also, is the top rad. hose hot? It should be...if not then it is your thermostat. Check coolant level too inside the rad in in resevoir.
Cimburke23
40
Feb 12, 2011 11:48 AM
