Injen Air Intake (Will it fit???) Exhaust (Will it fit????)
I'm looking at getting the Injen EIS, its the short ram with cold air extension. and also the greddy SP2 exhaust.
just wondering since i have my h22 in, and my catalytic converter is to small for the connecting pipe and such. Will i have to use the Accord Spec Exhaust & Intake?
My guess is use the Accord Spec Exhaust, and Use The H22a (prelude) Intake, can anyone tell me if i'm right??? thanx
I'd say you're correct. As long as the cat's position hasnt moved, the accord exhaust would be the way to go. If it had moved, you'd need a custom catback. There's no way a prelude exhaust would fit.
And yes, use the Prelude intake.
i've been told that 97-01 aftermarket prelude intakes will be your best bet...it has larger diameter piping so that it won't be constricted...the exhaust is obviously going to be from an accord, but i'd just cut off that cat if you don't emissions and just get a custom welded straight pipe welded on with a flange fitting the aftermarket exhaust...that's what i did and there is quite a gain in power when the cat is gone...
Mewgen
Jun 21, 2008 09:05 AM
epicforce
Aug 1, 2004 10:05 PM
jinxster
Jul 18, 2003 05:39 AM
