New injectors and fmu recalibrate.
i'm installing new injectors tomarrow along with a new diaphram for my fmu.The manual i have is suposed to be for 85-95 civics,crx's and del sols but it seems to concentrate mostly on 85-91 civics which is usless to me.There is only about 1/2 a page that tells you how to remove and re-install the injectors on the 5th gen civic and it's very vauge.Can somebody who has installed new injectors give me a breif description of how or what needs to be done.Any help or advice is greatly apreciated.Btw the engine is a jdm sir2 B16a.Thanks
5 gen...Just make sure to relieve fuel pressure(remove gas cap wait a few minutes) remove inlet line then behind the rail should be 3 10mm nuts holding the rail down that need to be taken out and fpr fuel line and the rail should slide right out. Just be careful with the o-rings and cushion rings that they aren't dried and crusty and if not I am sure you can reuse them though I would personally throw in new ones since the injectors are out already. Also before putting the rail with the new injectors already fitted into the rail back in, oil the o-rings (the ones fitted into the manifold side). Again I am quoting the process off my gsr but the concept should be similar to your engine. Good luck man.
Nick
Nick
Goto:
http://www.turbointegra.blike.com
Thats my webpage. Then click on How to, then click on Install injectors. I got all the info there.
Thanks for the info guy's.What type of lube should i use?I thought i remember hearing something about not using anything silicone based.Thanks again.
Nevermind the lube question i just clicked on the link and read up.
Btw great site it's informative,explains how to do things simply without making you feel dumb.
e jay one
Mar 26, 2007 03:58 PM
