H&R Springs for an 88 CRX
Old Jan 23, 2005 | 10:29 AM
Robster Craw's Avatar
Default H&R Springs for an 88 CRX
I'm considering buying the H&R spring set that lowers .75" front and rear.
what shocks should I run with those? Should i look at some koni specials.
is that going to cause and camber problems at all? I'm new to this lowering game.
88 seems to be the bastard child.
Old Jan 23, 2005 | 10:41 AM
mrspeaker's Avatar
Default Re: H&R Springs for an 88 CRX (K2500 Yo!)
Tokico illumina $300 from ebay..There adjustable and come with a lifetime warranty..
If you were lowering the car more then 2" then I wouldnt reccomend these but they would be good for your setup..
You wont have any camber problems with only a .75" drop..
You should still get it aligned though ..to be safe
I dont know if they make illuminas for a 88 though..
88-91 fronts are all the same..But the 88 rear has that bullshit eye setup where as the 89-91 have fork setup..You could just get some 89-91rear lower control arms though..Cheap from a junkyard,,
trianglegreg
Dec 13, 2005 06:14 PM
CRX_F1
Jul 13, 2005 08:24 PM
memphisraines26
Aug 9, 2004 09:32 PM
Combustion Contraption
Oct 26, 2003 03:05 PM
88 CRX SiR
Sep 19, 2001 08:51 AM
