Help!
Old Jan 23, 2005 | 10:22 AM
Bazza4788's Avatar
Default Help!
I was ****** abt with my civic today an managed to sum how break a bolt Its a 1.6 vtec the SINGLE cam one! It is on the rocker cover i done this and left it not started it or anythin! Wot should i do? Can i get it out? Have a fucked my engine?
Old Jan 23, 2005 | 10:28 AM
Luserkid's Avatar
Default Re: Help! (Bazza4788)
i have no clue what you did but broken bolt. Easy out?
Old Jan 23, 2005 | 10:57 AM
BauleyCivic's Avatar
Risky Business
Default Re: Help! (Luserkid)
Is it sticking out a bit? Or did you snap it off in the rocker arm assembly?
Old Jan 27, 2005 | 11:52 AM
Bazza4788's Avatar
Default Re: Help! (BauleyCivic)
Its going into the Bottom end! Where the rocker cover comes off its at the bottom of it and its not sticking out!
Old Jan 27, 2005 | 11:58 AM
POE's Avatar
POE
easy out, or drill in to it a little bit and then use a tapper and tap it out the try and tap it out the oppisite way u turned it.
Old Jan 27, 2005 | 11:59 AM
POE's Avatar
POE
next time dont tighten it so tight
EK squid
18
Jul 13, 2011 08:59 PM
CivicBlack
Feb 14, 2006 04:34 PM
00ekcoupe
37
Sep 5, 2005 06:15 PM
Geeq
Aug 3, 2005 02:46 AM
::mebri::
May 18, 2003 06:57 PM
