Master Cylinder bleeding question
Old Jan 23, 2005 | 09:58 AM
ham's Avatar
ham
Default Master Cylinder bleeding question
When changing out a brake master cylinder and bench bleeding the new one.....
can you just fill it with some fluid and pump it and let the fluid drip out? or do you have to run hoses back up to the reservoir and recycle it until all the air is gone.
Modified by ham at 10:34 AM 1/24/2005
Old Jan 23, 2005 | 11:12 AM
ham's Avatar
ham
Default Re: Master Cylinder bleeding question (ham)
Old Jan 23, 2005 | 12:43 PM
3.504's Avatar
recycle till the air is gone, use hoses on the ports and run them into the resevoir, fill the resevoir and pump (i use a push rod) till the air is gone.
Old Jan 24, 2005 | 04:32 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">... can you just fill it with some fluid and pump it and let the fluid drip out?</TD></TR></TABLE>You'll just have a bigger mess to clean up, & more fluid wasted.
Old Jan 24, 2005 | 06:11 AM
Takumi Fujiwara's Avatar
Default Re: Master Cylinder bleeding question (JimBlake)
What I did was put a hose on the end of the nipple on the slave cylinder that led into a can. (I had to do the bleeding myself). Anyway, I would fill higher than the max line on the clutch fluid reservoir, then go inside and pump the clutch while trying to see how much of the fluid in the reservoir was draining.... after a couple times, I closed up the slave nipple, closed the cap, and I was done.
Old Jan 24, 2005 | 06:34 AM
ham's Avatar
ham
Default Re: Master Cylinder bleeding question (Takumi Fujiwara)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara &raquo;</TD></TR><TR><TD CLASS="quote">What I did was put a hose on the end of the nipple on the slave cylinder that led into a can. (I had to do the bleeding myself). Anyway, I would fill higher than the max line on the clutch fluid reservoir, then go inside and pump the clutch while trying to see how much of the fluid in the reservoir was draining.... after a couple times, I closed up the slave nipple, closed the cap, and I was done.</TD></TR></TABLE>
im talkin about the brake master cylinder.
should have made that clear, my bad
ramboPandA
Jul 8, 2014 09:37 PM
maxogsr
Oct 4, 2009 01:51 PM
autoxthis
Honda Civic (2001 - 2005)
Aug 22, 2008 10:08 AM
autoxthis
Aug 21, 2008 11:12 PM
justbelowme77
Mar 17, 2005 06:05 AM
