Differenct between 05 and 02 Model, ECU, Parts, Etc......
Old Jan 23, 2005 | 01:48 AM
Chunty Butt Kevin's Avatar
Default Differenct between 05 and 02 Model, ECU, Parts, Etc......
Is the old 02-04 dc5 ecu the same as the 05 dc5 ecu?
What's the difference besides the look and the 10 more hp?
Would 02 parts fit on a 05?
Old Jan 23, 2005 | 08:58 AM
krystar's Avatar
the new ecu is completely new. it's not even the same plug. that's why 05's can't be hondata'ed.
there's tons of differences. new cams, new intake manifold, new exhaust, new ecu, new harness, new final drive, new gears, beefier suspension
Old Jan 31, 2005 | 01:39 PM
incogNitto's Avatar
Default Re: Differenct between 05 and 02 Model, ECU, Parts, Etc...... (SoFa king Slow)
http://forums.clubrsx.com/show...41852
2005 Changes:
210hp
143ft lbs tq.
Type R Final Drive, Lowered by 8.6 percent.
Single cone carbon synchronizers
Revised shifter bushings and spring
Type R Intake camshaft (valve lift increased 5 degrees)
Type R Exhaust camshaft (valve lift increase 10 degrees)
Intake Duct Increased 11 percent from 63mm to 70mm
Type R Exhaust (Larger diameter tail pipe from 60.5mm to 70mm)
Redesign Higher Flow Catalytic Converter (Exhaust flow increased from 95 liters per sec, to 98 liters per sec.
New dynamic damper added to the front subframe (reduce wheel hop, engine rocking and engine vibration)
New 17" alloy wheels with Michelin 215/45R17
New caster trail settings (increased 65 percent from 9.9mm to 28.6mm)
New camber angle (increased 50 percent)
Stiffer rear springs
New damper seals (improve ride comfort and reduce static friction)
Horizonal and Vertical rigidity of strut tower bar reinforced 13 percent and 26 percent.
Front compliance bushings adjusted (4mm longer stroke and 20 percent lower spring rate)
Front damper bushings replaced by bearings to decrease friction (wheels turn more easily and increase steering feel)
New front stabilizer bar increased from 23mm to 26.5mm, wall thickness increased from 2.8mm to 3.5mm.
Power steering pump flow increased 7 percent.
Quicker steering ratio (from 15.1:1 to 14.9)
Brake pedal stroke ratio reduced 5 percent
New flange add to brake pedal for 50 percent increase in pedal rigidity
Larger diameter brake master cylinder
New fuel tank shape, optimized to reduce fuel evaporation. Lowers emmissions by 75 percent.
New aggressive front bumper
New triple beam headlight w/blackout treatment
New rear bumper
New thicker exhaust finisher
New Taillights
New standard deck lid spoiler integrated into the trailing edge of the trunk lid.
New side sills
Coefficient of drag and coefficient of lift improved
Front body rigidity increased 15 percent w/ new front upper arm added and thicker wheelhouse walls.
Rear cross member rigidity increased 21 percent.
Additional insulation material in roof and doors.
Front seats optimized with thicker cushions and deeper side bolsters
Interior urethane padding thickness increased
Additional weather stripping reducing gap on side mirrors for smoother airflow.
New chrome accent for shift boot ring, hand brake **** and front seat headrest
New material for roof lining A-pillar garnish, quarter panel garnish and door lining
New black on white gauge cluster with chrome accent rings
Jdmbryan
Jul 20, 2012 05:40 AM
l0wboost.JSP
Northern California (Sales)
May 7, 2008 06:08 PM
skata89
Mar 12, 2006 08:21 AM
jaycuzz1
Jun 19, 2004 04:23 AM
JoeyBallzSI
Apr 25, 2004 05:13 PM
