PCV valve?
Old Jan 22, 2005 | 11:46 PM
crazyslowhatch's Avatar
Default PCV valve?
what would happen if the pcv vavle wasnt hook up? would it make the car run shity?
Old Jan 23, 2005 | 12:01 AM
mrspeaker's Avatar
Default Re: PCV valve? (crazyslowhatch)
Well if you put a block plate over where its suppose to be it will run better..
Did that to my fathers car and it doesnt stutter anymore..
I dont know what happens if you just leave it off though...?
Old Jan 23, 2005 | 12:48 AM
michael O's Avatar
Default Re: PCV valve? (Mrspeaker)
I *think* eventually oil will spit all over your engine bay in a fine mist.
Old Jan 23, 2005 | 01:11 AM
Default Re: PCV valve? (michaelOlson)
thanks
Old Apr 20, 2005 | 05:36 AM
acc9ord3's Avatar
would putting a small filter on the valve work?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">I *think* eventually oil will spit all over your engine bay in a fine mist.</TD></TR></TABLE>
Old Apr 20, 2005 | 05:45 AM
mr. carpenter's Avatar
Default Re: PCV valve? (acc9ord3)
why?
Old Apr 20, 2005 | 06:19 AM
oldSCHOOLhonda's Avatar
Default Re: PCV valve? (mr. carpenter)
u could install a breather on the line and plug the intake, but u have to have a pcv valve and it has to vent. (on a honda)
note, not only does it blow out of the pcv tube, but when hooked to the intake, it actually has a vaccume on this line aiding in clearing exsaust gasses from the combustion area.
gl
Old Apr 20, 2005 | 07:48 AM
drdisco69's Avatar
Yeah, without a PCV valve Hondas tend to idle funny.
vtec.dc2
Oct 15, 2006 10:19 AM
mastamind
Oct 4, 2006 02:36 PM
JMinSi2000
Nov 4, 2004 09:33 AM
DaX
May 23, 2004 07:11 AM
se93
Dec 27, 2001 06:11 AM
