where can i buy a 2" gauge that can tell me how much oil i have in the car
well an oil pressure gauge isn't going to tell you how much oil is in the car. An oil pressure guage will tell you oil pressure. Im not sure if there is an oil level guage, I bet there is though, but what I use is a dip stick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote">I use a dip stick. </TD></TR></TABLE>
Me too.
Me too.
no **** i know where is a dip stick i just would like a gauge so i'll be able to tell from inside the car and also i like the way ilooks on 91 civic but thans for the help dip stick (lol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant »</TD></TR><TR><TD CLASS="quote">no **** i know where is a dip stick i just would like a gauge so i'll be able to tell from inside the car and also i like the way ilooks on 91 civic but thans for the help dip stick (lol)</TD></TR></TABLE>
You dont need an oil level gauge. If you want something close though get an oil pressure gauge. If your oil pressure gauge suddenly shows low pressure, then you know that the system is not getting enough oil. So you are either low on oil or you have enough oil, but something is broken.
If you do decide to install an "oil level" gauge you might as well get some gauges installed to monitor your windshield washer fluid reservoir and your coolant overflow tank. Cause we all know how difficult it is to check the fluid levels on those.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90HFB16B »</TD></TR><TR><TD CLASS="quote">is that the flat thing with all the oily stuff on it?
Yeah, I think so, I need to check.
</TD></TR></TABLE>Yeah, I think so, I need to check.
Maybe rig up a switch in the sump area that would ground a low oil light(sounds mighty close to the function of an oil pressure switch) But you need to open the hood first.
whats so hard with checking oil everytime you fuel, or on cold start ups?
If your car burns oil so bad you need a Oil Level Meter than ill tell you what you need...
A F*CKIN REBUILD!!
A F*CKIN REBUILD!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitled »</TD></TR><TR><TD CLASS="quote">If your car burns oil so bad you need a Oil Level Meter than ill tell you what you need...
A F*CKIN REBUILD!!
</TD></TR></TABLE>rofl
A F*CKIN REBUILD!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant »</TD></TR><TR><TD CLASS="quote">can i use the oil pressure gauge or that for something else</TD></TR></TABLE>
"DIPSTICK!"
"DIPSTICK!"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano92Hatch »</TD></TR><TR><TD CLASS="quote">dont forget to rotate ur spark plugs!!
Omfg!!!!1oenoen!!</TD></TR></TABLE>
INDEXing the spark plugs is actually a good thing to do.
we did that using washers on all nitrous 1st gen CRX drag car.
1.8T_EG
Apr 18, 2003 08:00 AM
