wheel won't spin freely-e brake feels like it has no pressure
Old Jan 22, 2005 | 05:49 PM
hb_guy's Avatar
Default wheel won't spin freely-e brake feels like it has no pressure
just went to go to the bar and my rear drivers side wheel wont spin. wtf? my e brake feels like it isn't even connected when i realeased it. any suggestions? i'm thirsty and running out of cigarettes..
btw-97 civic dx with drums in the rear. car ran fine this morning. hmm...
Old Jan 22, 2005 | 05:52 PM
TeamNextGenChris's Avatar
Default Re: wheel won't spin freely-e brake feels like it has no pressure (hb_guy)
is it freezing *** cold where you are?if so,it's probably frozen.
Chris
Old Jan 22, 2005 | 05:54 PM
hb_guy's Avatar
Default Re: wheel won't spin freely-e brake feels like it has no pressure (TeamNextGenChris)
i thought of that but would that explain the loss of pressure in the e brake line?
yea it's stoooopid cold
i also checked the fluid and open the bleed valve and fluid was flowing, dont know if this helps
Old Jan 22, 2005 | 05:55 PM
CRXified's Avatar
ebrake cable could be froze on, thats y when u released it the handle goes down but feels really loose
Old Jan 22, 2005 | 05:58 PM
hb_guy's Avatar
Default Re: wheel won't spin freely-e brake feels like it has no pressure (CRXified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified &raquo;</TD></TR><TR><TD CLASS="quote">ebrake cable could be froze on, thats y when u released it the handle goes down but feels really loose</TD></TR></TABLE>
what to do? i wanna go drink
can i get under the car to release it? any ideas would help
why the hell would only one side freeze
Old Jan 22, 2005 | 06:07 PM
CRXified's Avatar
try backing up with it and drive forward a bit, might free it up, might not, its worth a try
Old Jan 22, 2005 | 06:08 PM
hb_guy's Avatar
i already tried that, my girl got in the car and i put my foot in the spokes and it moved but the ground in my complex is all frozen so i am just dragging it. hmm..
Old Jan 22, 2005 | 06:43 PM
hb_guy's Avatar
anyone?
Old Jan 22, 2005 | 06:59 PM
CRXified's Avatar
find some pavement, or wait till it warms up out man. dont know what to tell ya, take a taxi
Old Jan 22, 2005 | 07:00 PM
hb_guy's Avatar
lol.. thanks
Old Jan 22, 2005 | 07:15 PM
Soccerking3000's Avatar
and just so you know the ebrake only engages the back left
Old Jan 22, 2005 | 08:05 PM
Default Re: wheel won't spin freely-e brake feels like it has no pressure (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">and just so you know the ebrake only engages the back left</TD></TR></TABLE>
what?!have you ever actually looked?both rear brakes are engaged.
only thing i can suggest is find a way to warm up the car.can you get it into a garage maybe?
Chris
Old Jan 22, 2005 | 08:26 PM
hmmm, my dads truck locks only one side lol, i thought they were the same, guess not
Old Jan 22, 2005 | 09:36 PM
TallAssFilipino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, my dads truck locks only one side lol, i thought they were the same, guess not</TD></TR></TABLE>
WTF?! lmao...
Anyway, yeah, both our rear are engaged by the e-brake. Since it's cold out and you can't really do much around/outside the car, go inside and remove the center console piece so you can see the two cables that attach to your e-brake handle. See if either of the two cables move as you release/engage your e-brake handle.
Old Jan 22, 2005 | 09:37 PM
hb_guy's Avatar
thanks
Old Jan 22, 2005 | 10:15 PM
Default Re: wheel won't spin freely-e brake feels like it has no pressure (MDJ IKNJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDJ IKNJ &raquo;</TD></TR><TR><TD CLASS="quote">
WTF?! lmao...
Anyway, yeah, both our rear are engaged by the e-brake. Since it's cold out and you can't really do much around/outside the car, go inside and remove the center console piece so you can see the two cables that attach to your e-brake handle. See if either of the two cables move as you release/engage your e-brake handle.</TD></TR></TABLE>
its an old truck i dunno maybe sumthins broke
Old Jan 23, 2005 | 07:56 AM
hb_guy's Avatar
cables dont move-any ideas how to get them to move?
car has been warming up outside now for over an hour. i'm gonna go check on it. see what happens.
Modified by hb_guy at 5:22 PM 1/23/2005
alright-got it rolling. i disconnected the bracket that holds down the e brake cables inside the car. that let the cable move enough for the wheel to spin. i am just gonna leave it disconnected until i can take the wheel and drum off to inspect/clean/change whatever needs to be changed. thanks for everyone's help
Modified by hb_guy at 6:38 PM 1/23/2005
Old Jan 23, 2005 | 12:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hb_guy &raquo;</TD></TR><TR><TD CLASS="quote">cables dont move-any ideas how to get them to move?
Modified by hb_guy at 6:38 PM 1/23/2005</TD></TR></TABLE>
i'd say it's still at lleast partially frozen.the hub/drum area doesn't get warmed any if you let the car run and warm up,so letting the car run won't get the brake unfrozen.getting the car moveable,and driving it some will heat things up enough to fix it.
Chris
Old Jan 23, 2005 | 12:35 PM
jlacoy82's Avatar
71.192.16.183
Pull out the butane torch!
Old Jan 23, 2005 | 12:43 PM
_Cyclone_'s Avatar
Default Re: (jlacoy82)
It's not frozen. This happened to an EK that we E-tested last year, I got in it and tried to drive, but the left rear wheel was stuck and the ebrake handle had a similar feeling to what he described. I told one of the mechanics what was happening, and he went outside and fixed it. I didn't see what he did exactly because I had other cars to test, but I know he had that wheel off, and he told me he had to back the shoes off from the access hole on the backing plate.
Old Jan 23, 2005 | 03:26 PM
hb_guy's Avatar
Default Re: (CycloneBlue_1.6EL)
thanks and the rear drum is coming off tomorrow
Old Jan 23, 2005 | 03:30 PM
ej1 pilot's Avatar
Default Re: (hb_guy)
put a tray or a skateboard under the wheel
Old Jan 23, 2005 | 04:55 PM
hb_guy's Avatar
Default Re: (Art In Motion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion &raquo;</TD></TR><TR><TD CLASS="quote">put a tray or a skateboard under the wheel </TD></TR></TABLE>
read grasshopper! it already rolls
Old Jan 23, 2005 | 05:01 PM
CRXified's Avatar
get this fixed yet?
Old Jan 23, 2005 | 06:23 PM
its an old truck i dunno maybe sumthins broke </TD></TR></TABLE>
Better let him know about it, lol.
