my steering wheel has turrets?????
Old Jan 12, 2002 | 05:35 PM
Jmm0056's Avatar
Default my steering wheel has turrets?????
ok after braking my steering wheel starts twitching really badly, does anyone have a clue whats wrong with it? i was thnking myabe something with the power steering pump or somehting because the wheel jerks to the left very abruptly, i think i need an alignment but i dont think that is the cause of this problem because it started doing it all of the sudden tonight, anyone have any clues? thanks
Old Jan 12, 2002 | 05:48 PM
Phat Corolla's Avatar
New User
Default Re: my steering wheel has turrets????? (Jmm0056)
Tourettes?? That's hilarious! It could be that your rotors are warped, since you say this is happening when braking. You also say it pulls to the left...how long has it been since you've bled your brakes? You might want to do that. Also, you should check the left brakes to see if something has malfunctioned in the acutal brake assembly. Good luck!
Old Jan 12, 2002 | 05:53 PM
Jmm0056's Avatar
yeah well its not happenening while braking its like after i brake, then the turrets syndrome starts it is really odd, the car pulls somewhat to the right because i think it needs an alignment but the steering wheel jerks back to the left very abruptly, and it just started doing it an hour ago it wasnt like a graduall process, just all of the sudden............... any more suggestions?
Old Jan 12, 2002 | 05:57 PM
GSRaCeRbOI's Avatar
i think your rotors are warped since you say the steering wheel moves back and forth right? also check your tires to see if there are any visible bubbles on the tread or anything.. the wobbly steering wheel is probably a warped rotor..but the pulling to the left could be a number of things.. have you had an alignment? have you bled the brakes? or maybe the brakes are sticking for some reason? check the caliper pin bolts too..
i just got new rotors on my car after about 40K cuz they were warped..
$28/ea + $10 shipping ea for Brembo Blanks OE (www.collettimotorsports.com) they shipped them out quickly and customer service is very good.. also got hawk HPS pads..
[Modified by GSRaCeRbOI, 8:49 AM 1/13/2002]
Old Jan 12, 2002 | 06:00 PM
Jmm0056's Avatar
Default Re: my steering wheel has turrets????? (GSRaCeRbOI)
yeah maybe it is the rotors, i guess i'll be checking it out tomrorow when i can see, thing is that is isnt doing it all the time either, its primarily after i have slowed down from about 60 and am doin about 40 that it happens and the steering wheel twitches uncontrollably, but its not every time either, bah....................
Old Jan 12, 2002 | 06:10 PM
rjardy's Avatar
make sure everything is tight! I got a set of front rotors pretty warm one time and **** started to back out on me. Shared the whole turrets thing , good luck man
Old Jan 13, 2002 | 08:52 AM
MattG's Avatar
New User
If its after braking there is a possibility the caliper is sticking.
Old Jan 13, 2002 | 11:03 PM
Jmm0056's Avatar
Default Re: my steering wheel has turrets????? (MattG)
yeah thats what is so confusing me, its not doing it after braking, just randomly while driving, anybody think it might be the power steering?? if its cutting in and out couldnt it cause the ecleptic jerking that makes me think my car has turret sydrome?
Ohbebe75
Oct 24, 2015 07:50 AM
TOO MUCH TORQUE
Aug 15, 2010 06:53 PM
20-EM2-05
Acura TSX
Aug 4, 2009 07:39 PM
jpopvriens
Jun 2, 2007 12:40 PM
Jmm0056
Jan 13, 2002 06:08 PM
