90-91 VS. 92-93 Clutches
Old Jan 22, 2005 | 02:58 PM
B18aHatch's Avatar
Default 90-91 VS. 92-93 Clutches
I am tryin to find an Exedy Stage 2 clutch, and found one for a 92-93 but my teg is a 90. are all g2's the same? will the 93 fit my 90 np? thanks for the help all
Old Jan 23, 2005 | 09:54 AM
b62pteg#2's Avatar
Default Re: 90-91 VS. 92-93 Clutches (B18aHatch)
No you can't use a clutch for a 92-93 teg tranny in a 90-91 teg tranny, because the input shaft splines are different. If you buy the whole clutch assembly, then yes, but no for the question you asked.
If you haven't been to http://www.g2ic.com then check it out bc its a 2nd gen teg only site...I've been a member there a lot longer then here. Point is this topics been covered over there a lot.
Oh and I did a real quick search on eBay for an Exedy stage 2 clutch and found this:
http://cgi.ebay.com/ebaymotors...=WDVW
Or you can just search ebay under "integra exedy", "integra exedy 90", etc.
HTH -- Kevin
stp_vtec_boi
May 12, 2006 10:24 AM
skunk2powered
Nov 18, 2005 04:21 PM
the DA in HONDA
Oct 20, 2004 06:22 AM
bluecrxsi
12
Feb 15, 2003 06:02 AM
