is it hard to install a radiator?
Old Jan 22, 2005 | 11:06 AM
redINTEGRAdriver's Avatar
Default is it hard to install a radiator?
ok im going to replace my radiator with a new one and i want to know if this is a hard task or if its like a bolt on task? just any expierienced peoples advice would be helpful.respect.
Old Jan 22, 2005 | 11:10 AM
timmy8151's Avatar
Default Re: is it hard to install a radiator? (redINTEGRAdriver)
Try this article: http://www.team-integra.net/se...D=763
It's a fairly easy thing to do. While your at it, change your thermostat too.
Old Jan 22, 2005 | 01:21 PM
aeon's Avatar
yeah it's really easy, I did it myself and it took me about 2-3 hours and that included flushing and filling up the radiator fluid. I'm a really slow worker so it should only take you about half the time it took me, I just take my time on things.
Old Jan 22, 2005 | 01:32 PM
bigbusiness's Avatar
It's pretty easy, when my friend messed up the front end of his car he had to change his out and it went pretty smooth.
Old Jan 22, 2005 | 01:47 PM
escape2me's Avatar
Default Re: is it hard to install a radiator? (bigbusiness)
I strongly recommend Radiators.com.... I got about 100 dollars off from them and thye diliver the same day, Little tip it may sound weird but when you start talkin to the automated radiator guy online ask if it is a computer you will a 25 dollar discount
Old May 16, 2005 | 10:06 AM
SamC's Avatar
Default Re: is it hard to install a radiator? (97 GSR)
I've just install the radiator this weekend. The hardest part I think was putting on the new upper and lower hoses. Any hints on putting them on next time?
Old May 16, 2005 | 07:02 PM
cleantegra's Avatar
Default Re: is it hard to install a radiator? (SamC)
never replaced on t an integra but when i did it on my civic, it was cake. took me about 30 minutes, didnt even flush the coolant. oh yeah and about the hoses i used a little grease even though not the best thing to do they slid right in
Old May 16, 2005 | 07:10 PM
Racermech's Avatar
Default Re: is it hard to install a radiator? (cleantegra)
Easy Easy Easy. That is one of the first things I ever did to my car. I will search for a thread we had a while ago about replacing a radiator
Old May 16, 2005 | 08:49 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: is it hard to install a radiator? (Racermech)
bookmark
Old May 16, 2005 | 08:56 PM
SamC's Avatar
Default Re: is it hard to install a radiator? (ArizSun21)
The hoses took the longest and was the hardest part beside taking off the 2 themostat bolts. Oh, taking it off was easy, since i just cut up the old ones
Old May 16, 2005 | 10:05 PM
no2unenolife's Avatar
e-z
Old May 16, 2005 | 11:07 PM
Bibnation3's Avatar
very easy... took me about 45 min - 1 hr... but that is after watching a mechanic changing a radiator the day b4
Old May 17, 2005 | 05:59 AM
OrangeCountyGSR's Avatar
Default Re: (Bibnation3)
If you lube the hoses up with silicone spray, they should slide on and off really easily...Also, make sure to take the rubber bushings off of the old radiator and put them on the new one.
Old May 17, 2005 | 06:45 AM
Tweakmeister's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArizSun21 &raquo;</TD></TR><TR><TD CLASS="quote">bookmark</TD></TR></TABLE>
pwned
use a little soap on the tubes when putting them on...slides like butter.
Old May 17, 2005 | 09:55 AM
SamC's Avatar
Default Re: is it hard to install a radiator? (Tweakmeister)
haha..i thought about using silcone spray or wd40 on the hoses, but wasn't sure if that's okay to mix with coolant. Well, now I know...
94Vtecluder
Nov 18, 2007 09:12 AM
fackyou
Mar 13, 2007 11:05 AM
RevOnRacerz
May 13, 2004 10:02 PM
munscher
Mar 31, 2004 11:12 AM
blacks2000
Jul 28, 2002 05:12 PM
