Distributor Question!
I was wondering if it was possible to switch the internals out of my 91 CRX SI dist. and put them into a 96+ distributor? Im doing this because i dont want to use the d16a6 distributor on my d16y8 (im staying obd0). Will everything bolt up correct on this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civichatchback »</TD></TR><TR><TD CLASS="quote">I was wondering if it was possible to switch the internals out of my 91 CRX SI dist. and put them into a 96+ distributor? Im doing this because i dont want to use the d16a6 distributor on my d16y8 (im staying obd0). Will everything bolt up correct on this?</TD></TR></TABLE>
If you're staying obd0 why not use the A6 dizzy on the y8 head.??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker »</TD></TR><TR><TD CLASS="quote">
Ditto, the a6 should bolt to the y8 head. Plus you will probably run into shaft diameter difference problems with the exciter ring/ring driveshaft etc.
