Who has installed OEM optional sides - need a little info
Are these supposed to come with rubber gaskets? If they are missing, will it compromise the install (e.g by wearing through the paint on the body panels underneath)? TIA
On the real ones, the rubber should already be there. Without it, it'll probably rub up against the 1/4 panel and rear bumper and leave marks after time.
I was hoping maybe that would work. Is it just a 'U' shaped piece of rubber edge stripping, or does it have some larger flat part to it?
Does it just go under the edge of the rear part of the side skirts where they overlap the 1/4 panel?
Thanks!
Thanks!
someone posted a while back that they found a perfect replacement for the "gasket" or weather stripping, i'll try and locate it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curt941 »</TD></TR><TR><TD CLASS="quote">damn, i'm the ******* man.
https://honda-tech.com/zerothread?id=1071790
Hell yeah you are
I missed that post.
No prob Jdmspoonitr. Those things are hard to come by - I'd keep mine too, until I was sure I had no use for them anymore. If you change your mind, hit me back.
BTW - Any idea on price? Part # for the ITR one?
</TD></TR></TABLE>Hell yeah you are
I missed that post.No prob Jdmspoonitr. Those things are hard to come by - I'd keep mine too, until I was sure I had no use for them anymore. If you change your mind, hit me back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01ITR0716 »</TD></TR><TR><TD CLASS="quote">you can buy a aftermarket rubber for it.</TD></TR></TABLE>
welcome to 6 hours ago.
91b16acrx
Nov 9, 2008 12:19 AM
No way of replacing or fabricating the gaskets if they are missing?
