94 integra, alarm question on factory door lock using the DEI module install. plz help
i did installed an alarm like a month ago on my 94 integra with the factory door lock. i just bough a DEI module so i can control the door lock unit when i press the alarm.
my question is how do i installed it, its much diff than installing it on a civic with an actuators.
modules have purple 12volt, brown, white, blue,green, and the plug that goes into the alarm module. any help would be great????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic »</TD></TR><TR><TD CLASS="quote">i did installed an alarm like a month ago on my 94 integra with the factory door lock. i just bough a DEI module so i can control the door lock unit when i press the alarm.
modules have purple 12volt, brown, white, blue,green, and the plug that goes into the alarm module. any help would be great????</TD></TR></TABLE> You don't need the module just use the neg. (-) doorlock trigger output of the alarm and wire them to black/white - lock and black/red - unlock , found behind drivers kickpanel
94
94
dammit. thanks for the tip. i didnt even know that cuz i use the module for the civic since the civic dont have factory door lock. so i just use the two wires from the alarm module.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic »</TD></TR><TR><TD CLASS="quote"> so i just use the two wires from the alarm module. </TD></TR></TABLE>Yes
94
94
